Boot Door Sticking
24 replies to this topic
#1 Silverdogs
Silverdogs
  • Budding Enthusiast
  • 53 posts
  • Name: Sarah
  • Ford Model: Mondeo TDCi estate
  • Year: 2003
Posted 07 June 2013 - 11:05 AM
Hi everyone, I'm having trouble getting my boot door open and it's not as if I can open it with a key because there isn't a keyhole, just this fingertip thingy underneath the sill. I don't know how it works but it's not releasing the mechanism when I put my fingers on it and I have to fiddle around a bit to get it open. Annoying at the best of times but when I've got the dogs standing waiting to get in or they're already in and I can't get the door open it's even more annoying!
I thought it was the mechanism inside sticking so I've put some WD40 on it but it didn't seem to make any difference, so I presume it's the bit underneath the rubber handle. Is this an electrical thing?
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,958 posts
  • Name: James
  • Year: 2007
Posted 07 June 2013 - 12:38 PM
certainly seems it. Although your car isnt a CMAX, take a look at this thread: http://www.fordowner...pening-problem/
as it shouldnt be too disimilar...
#3 gforce
gforce
  • True Ford Enthusiast
  • 819 posts
  • Name: Gary
  • Ford Model: Mondeo ST
  • Year: Non
Posted 07 June 2013 - 01:57 PM
Common fault on the Mk3 Mondeo, and most Fords it would seem as my Focus is playing up now too!
When it went on my Mondeo I first replaced the lock mechanism (about £70ish) as the solenoid/motor were known to go, but this didn't cure it so I replaced the micro-switch then too (about £25ish) all under warranty and it was good as new.
Do you have a button on the key fob? Does the interior boot release work? Does it have any random opening issues?
#4 Silverdogs
Silverdogs
  • 53 posts
  • Name: Sarah
  • Year: 2003
Posted 07 June 2013 - 04:16 PM
Oh yes it does have a button on the key fob, I forgot about that, I never use it. I don't think it has an interior boot release, I'll have to look more closely, the only release that stands out is the fuel flap.
I haven't had any random opening issues thankfully, that would be very dangerous with the dogs in the back as I haven't got a tailgate guard yet. I always lock the doors when the dogs are in the car.
Is the rubber handle stuck to the metal? I tried to get it off earlier but it seems to be stuck down fast.
So I'll try replacing the switch first if it's as easy as the man on the other thread said, but I won't be taking any meeces apart. :lol:
#5 Silverdogs
Silverdogs
  • 53 posts
  • Name: Sarah
  • Year: 2003
Posted 07 June 2013 - 04:29 PM
OK I haven't had the car long, well a couple of months, but I hadn't noticed the boot release button inside. :rolleyes: I'm not blonde, honestly. :lol:
#6 gforce
gforce
  • 819 posts
  • Name: Gary
  • Year: Non
Posted 08 June 2013 - 11:22 PM
Haha, no worries mate, can take a while to get used to.
There's a chance you could take the switch out and give it a clean, give it a spray with WD40 or some sort of contact cleaner and see how that goes, but might only be a temporary fix.
If you remove the interior boot plastics, then 6 x 10mm bolts to remove the tailgate handle piece you can pop out the rubber switch then.
Another option is if you disconnect the boot switch, the interior release button and the keyfob button should still work fine. Some people actually did this, not as a fix but as a security measure, to stop the boot being so easily accessible when stopped at traffic lights for example.
#7 Silverdogs
Silverdogs
  • 53 posts
  • Name: Sarah
  • Year: 2003
Posted 09 June 2013 - 02:48 PM
Perhaps it's a good thing after all then, I don't want someone opening the boot and letting my dogs out. I hate not having a tailgate guard but we spent all our money on buying the car and had nothing left, not even £50 for a warranty.
#8 Silverdogs
Silverdogs
  • 53 posts
  • Name: Sarah
  • Year: 2003
Posted 29 December 2013 - 11:58 AM
The boot switch has been working ok and I've had more urgent things to sort out like a new clutch and windscreen. I went out this morning, put the dog in the boot and now I can't lock it because the switch isn't releasing - the opposite problem from what I had before. I can't drive around with the boot open so can't drive the car until I get the switch replaced. Is there a way of getting it to release so I can shut the boot door?
#9 Silverdogs
Silverdogs
  • 53 posts
  • Name: Sarah
  • Year: 2003
Posted 29 December 2013 - 12:57 PM
How do I disconnect the boot switch?
#10 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,958 posts
  • Name: James
  • Year: 2007
Posted 30 December 2013 - 11:20 AM
You need to remove the plastic cowling from the inside of the boot door, then you have access to the boot switch behind the panel.
Its easy enough to do, the connector is easy to see!
#11 Silverdogs
Silverdogs
  • 53 posts
  • Name: Sarah
  • Year: 2003
Posted 30 December 2013 - 11:28 AM
We've just had a look and WD40'd it but still nothing, not even from the switch inside the car or key fob remote. :( We've fastened it down with a bungee until I can get it into the garage but that won't be until Thursday because of silly bank holidays.
#12 Silverdogs
Silverdogs
  • 53 posts
  • Name: Sarah
  • Year: 2003
Posted 30 December 2013 - 11:30 AM
Oh I've just realised we didn't disconnect anything, just WD40'd it but I'm not telling my husband to go back and do it again!
#13 mick85
mick85
  • 924 posts
Posted 30 December 2013 - 11:57 AM
This a micro switch they give bit trouble wat is ur car year an model does boot open wit remote
#14 Silverdogs
Silverdogs
  • 53 posts
  • Name: Sarah
  • Year: 2003
Posted 30 December 2013 - 12:12 PM
It's a 53 TDCi estate. It won't lock, not with the remote, the handle or the switch inside. What a ridiculous idea not having a keyhole!
#15 mick85
mick85
  • 924 posts
Posted 30 December 2013 - 12:18 PM
So if u open boot get big screw driver an manually push it the lock closed won't lock is the lock seized
Not what you're looking for?
