Markc1982 Posted June 14, 2013 Share Posted June 14, 2013 Hi All, Hoping to get some advice from you if possible? I have a 2008 Ford Fiesta Zetec Blue and i've only gone and had a minor bump this afternoon. I've drove the car home afterwards and upon inspection i've noticed a wire hanging between the front grill just above/behind the front number plate. I am already aware that Ford number all parts and this reference i can see is ford fiesta part 6s6ha001a04. I just wondered if any of you know what this wire could be, is my care safe to drive, will a repair be expensive and if it'll be an easy fix? Also, from my search i'm thinking it could have something to do with the outside temp as this is currently showing as - - on the display?? The car is running NORMAL and i managed to get it home afterwards (not sure if that was a good thing) I've just been down, turned the engine over and all seems well no noise and no lights on the dash? Can anyone help or point me in a direction. Any info on prices for a fix would be great Thanks Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted June 14, 2013 Share Posted June 14, 2013 Can you take a picture of the wire thats loose? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 14, 2013 Share Posted June 14, 2013 Definitely sounds like the external air temp sensor has got damaged or got disconnected. Is the connector intact or is the wiring broken? Quote Link to comment Share on other sites More sharing options...
Markc1982 Posted June 14, 2013 Author Share Posted June 14, 2013 Hi Stoney871 thanks for your reply :) ! I think the connector is intact? and as for the wiring, well it's still connected to it's place on the car if that makes sense? I've had a closer look as possible and it looks like a figure 8 connector, you know the like you would get on a play station or a kettle lead? Like i said, the car runs ok and no lights on the dash? Also i didn't mention the hissing noise? Just after the bump i had earlier i could hear a hissing sound from under the bonnet, this has since stopped but i wonder if it's connected?? Thanks again for hellping! Quote Link to comment Share on other sites More sharing options...
Markc1982 Posted June 14, 2013 Author Share Posted June 14, 2013 DanGersFord sorry i seem to have overlooked your reply. I'm going down to the car now to see if i can take a pic of the wire while it's still light brb Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 14, 2013 Share Posted June 14, 2013 The temperature sensor is purely a courtesy thing and shouldn't affect the running of the car. Hissing sounds ominous, have you checked your aircon (if fitted) to make sure you haven't ruptured a coolant line? Quote Link to comment Share on other sites More sharing options...
JasonEdwards Posted June 14, 2013 Share Posted June 14, 2013 Yes most probably you outside temp sensor as they are located right behind the front bumper. How hard was your 'bump'? Check to see if your air con works, the light on switch will still work but the compressor may not be cutting in. If the 'bump' was quite hard then you may have damaged the air con condenser (air con radiator) and the hissing noise was the gas escaping. Bumpers are good at hiding hidden damage after a bump!! Quote Link to comment Share on other sites More sharing options...
Markc1982 Posted June 14, 2013 Author Share Posted June 14, 2013 @DanGersFord I've attached pics hope they are clear enough and help? http://sphotos-h.ak.fbcdn.net/hphotos-ak-prn1/1017238_10201373048358452_308359620_n.jpg http://sphotos-b.ak.fbcdn.net/hphotos-ak-ash3/1010560_10201373049638484_2033101296_n.jpg Quote Link to comment Share on other sites More sharing options...
Markc1982 Posted June 14, 2013 Author Share Posted June 14, 2013 Hi Stoney871 i havent checked the air con, i'll check now and post. thanks Quote Link to comment Share on other sites More sharing options...
Markc1982 Posted June 14, 2013 Author Share Posted June 14, 2013 Thanks for the advice Jason, i wasnt going fast and was in 2nd gear when my foot slipped from the break and i rolled into the car in front, strangely also a a Ford Fiesta. Just going to check the air con Thanks Quote Link to comment Share on other sites More sharing options...
Markc1982 Posted June 14, 2013 Author Share Posted June 14, 2013 Jason/Stoney871 just been to the car and ran the engine for a moment again all seems fine. I've switched on the air con and it seems to be blowing cold air but it's a cool night here so unsure if it's air con or just fresh air? Also, i checked the coolant levels and they are at the normal level if that helps?? Quote Link to comment Share on other sites More sharing options...
geoyakult Posted June 24, 2013 Share Posted June 24, 2013 I have the a similar problem with my outside temperature on the digital dash ... From your pictures looking like you've damaged or popped the temperature sensor out .... I'm gonna check mine too and see if it's the same part as your picture. Quote Link to comment Share on other sites More sharing options...
