shaunyboy
Clunking/knocking Sound When Turning Steering Wheel
Hi I'm new to this forum and just looking to see if anyone else has had a similar issue.
I own a (2000) Ford Focus and only recently I have started hearing a clunking/knocking sound from under the car... after checking everything I could, I have now found that the sound comes when I turn the steering wheel from side to side... Particularly when going at a slow speed or turning round a corner.
Can anyone advise? I fancied trying to find out the answer before I handed the car into the garage!
It will either be droplinks or ball joints however on the mk1 it coukd be the steering rack has gone its quite common
Is the steering rack a costly job?
Is there anything I can do to identify this before handing over to the garage?
Thanks all.
you wont see much change from £500-£700 depending on rates either way its suspension or steering related so needs diagnosed by a mechanic if youre lucky its just a worn ball joint
I had a similar issue on my old Fiesta. I took it to the garage and I'd completely snapped the front right spring. But after they replaced it I still got a slight clunking sound.
