AdBlock Warning
bassbella69
Hello From A Newb, Bluetooth Query...
4 posts in this topic
Hey guys. I've just bought myself a Ford Focus 2008 with a Sony DAB CD radio (not the 6 disk changer). I've checked ETIS and it does say I have Bluetooth control etc. The radio control stalk has the 'Voice' button but nothing happens when I push it. Also when I push the phone button on the radio it mutes but nothing else. There is no bluetooth option on the menu. I've been told I can reset the bluetooth unit but I'm having trouble locating it. I've taken the panels off in the footwell but I don't really know what I'm looking for.
Any ideas where is it?
post-44455-0-37372100-1371397850_thumb.j
You want to be looking for a module like this-
http://i.ebayimg.com/t/FORD-BLUETOOTH-VOICE-CONNECTIVITY-WITH-USB-HANDSFREE-MODULE-CS7T-14D212-AC-/00/s/NjgyWDEwMjQ=/z/-0EAAOxy7MtRxXsC/$(KGrHqJ,!rYFG-llUoTCBR)(sBzyhw~~60_12.JPG
It should be tucked up behind the removable panel to the left of the drivers footwell but will be pushed quite well forward.
All you do is connect to the bluetooth via your phone and its good to go in mine... dont know if this helps!
Took ages to find my BT module, it was on a bracket beneath the passenger airbag and above the glovebox; because of that I couldn't reach the cable lock tag :censored:
Coupled with that it was mounted upside-down so the torx screw head was facing the bottom of the airbag.
To get it it out I had to tape a torx-bit to a tiny spanner and undo it 1/6th of turn at a time and of course it wasn't a short bolt either :cry:
Left it disconnected for about 30mins after which it worked; I put it back the other way up (or should that be down ?) so I could get the screw out easier next time.
