Dazzl360
Fuse For Buttons On Steering Wheel??
Hi all!
This morning I replaced a broken 20AMP fuse as my 12v power socket was not working.
The socket is now working again although ive noticed the audio buttons on my steering wheel are not.
Can this be due to a broken fuse? If so which one and what AMP?
Many thanks!
I had problems with none of the steering wheel buttons working, except for the M button. This got fixed at my dealer, they did a reset or something like that with their IDS.
Ah right, not even the 'M' is working on mine. Thats why im thinking fuse.
Ive found a list of all the fuses on the internet so ill check to see if anys tripped tomorrow.
If not ill have to pop down to the dealers.
Cheers!
Does the button light up when you turn your lights on?
Yes, The lights come on the wheel and dash as normal. Ive checked the fuses and they are fine. Im thinking the car needs re-setting so i might disconnect and reconnect the battery. Hopefully that will work.
Sorted! Everythings working fine and back to normal now ive disconnected and reconnected the battery.
Typical IT solution, turn it off then on again, that's what our IT "experts" always start with.
