derek4607 Posted June 18, 2013 Share Posted June 18, 2013 hello can any one help me i cant engage 5th or reverse gear the gear lever will not push over to the right 1st 2nd 3rd 4th all fine many thanks derek Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 18, 2013 Share Posted June 18, 2013 sounds like a gear selector / linkage problem... have you had a look at the mechanics underneath the stick... something as simple as a small item falling down into the well could stop it being shifted to the right... Quote Link to comment Share on other sites More sharing options...
derek4607 Posted June 18, 2013 Author Share Posted June 18, 2013 hello jeebowhite had a look nothing stuck on gear selector if i disconect cables leaver moves alright Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 18, 2013 Share Posted June 18, 2013 so its a gear linkage issue by the seems of things. Unfortunately I cant really say how is best to fix it, I would advise that you are probably best placed taking it to an independant garage. They may be able to release the cable and unstick it if it is seized shorted than it should be, but I wouldnt know where to start in advising you how to fix it... Quote Link to comment Share on other sites More sharing options...
Morgie Posted June 27, 2013 Share Posted June 27, 2013 sounds like syncro mesh gone 5th and R share the same one im sure defo a sncro though . Quote Link to comment Share on other sites More sharing options...
