Badcleva
Turbo Oil Feed And Return Pipes - How To ?
Hi folks,
I have tried to get some info on this , but finding someone with real TDCI knowledge is suprisingly hard work! I'm hoping someone may be able to help ;)
Basically I have oil spewing out of what I am pretty sure is the turbo oil feed pipe. I obviously need to replace the pipes, both feed and return.
I have removed the return pipe where it enters the block by the sump, that was simple enough and I have removed one of the return pipe securing bolts at the top of the return pipe where it meets the turbo and I am sure with a bit of messing I'll get the other one.
What I am struggling with is getting the feed pipe off at the turbo end and the end where is enters the block right behind the alternator :angry:
Other than the turbo heat shield and air intake I haven't removed any ancillaries. I have read elsewhere that it's an easy job, I am now beginning to wonder !!
Any help please ?
