Ant c
Drive Shaft Broke
4 posts in this topic
I got a mk1 focus an the other day i was drivin an my steerin wheel started shakin at 20mph then wen i went to pull off at a round about i heard a bang an my drivers side drive shaft had come off the wheel side and i had bearings and bit of metal were on the road does any 1 have any ideas why this might of happened ?
cv joint collapsed, wouldnt recommend just changing the outer joint, when they break up like this you would be better off changing the whole shaft
Moved to focus section
Have a look at the other one and check the boot condition, if it becomes damaged and oil leaked out it will fail and fall apart
