thecarpman
Puddle Under Engine
i sat waiting to pick wife up from work for 20mins with air con on and when i moved out of parking space there was a puddle of warm water under engine is this normal or do i have a leak??? as once i got home i turned of air con and just had the blower on full sat for 20mins and looked under the car and there was no water
That's perfectly normal and to be expected, it's simply the moisture which the air con removes from the air. Hence why it wasn't there once you turned the aircon off!
