stokerfatlad Posted June 20, 2013 Share Posted June 20, 2013 hi all iam a newbie i have been a member about 5 months and i have a 2 litre desiel , i am hoping someone can give my good advise on my boot lock i have replaced the lock and had the catch micro switch checked the rear fuse No 5 and still cant get the boot lock to work iam at a loss to where to go now as anybody had this problem? Quote Link to comment Share on other sites More sharing options...
gregers Posted June 20, 2013 Share Posted June 20, 2013 check for broken wires in the rear door gaiters. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 21, 2013 Share Posted June 21, 2013 Also check that there is no water in the switch area underneath the rubber cover. Quote Link to comment Share on other sites More sharing options...
stokerfatlad Posted June 23, 2013 Author Share Posted June 23, 2013 hi guys thanks for your ideas i have checked them out but still no joy got any more thoughts cheers dave Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 24, 2013 Share Posted June 24, 2013 when you try to open it, do you feel the switch click? do you hear any noise? are you able to force it open from the inside (I believe there is a handle in the boot somewhere? Quote Link to comment Share on other sites More sharing options...
stokerfatlad Posted June 26, 2013 Author Share Posted June 26, 2013 hi there is no noise from the switch but you can feel it and i did remove it and checked the switch was letting currant past when operated and it did, there was no handle on the inside but i have fitted a cable to the catch so for te monment i can open it from inside.thank you for your thoughts cheers dave Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 27, 2013 Share Posted June 27, 2013 In that case, it might be a catch issue. Are you able to force the boot open (not sure if the SMAX has an inside handle for emergency release?) Quote Link to comment Share on other sites More sharing options...
stokerfatlad Posted June 27, 2013 Author Share Posted June 27, 2013 hi the catch is working ok and the s-max has,nt got a handle inside the boot but i agree they should have one i have decided to try a new micro swicth on the handle as mine may not give the correct volts i let you no how i get on it may take a week as iam in germany for a week cheers dave Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 28, 2013 Share Posted June 28, 2013 Enjoy your week away Dave, looking forward to a resolution! :) Quote Link to comment Share on other sites More sharing options...
stokerfatlad Posted September 7, 2013 Author Share Posted September 7, 2013 hi all just a quick update i checked all wires coming from car to tailgate and couldnt a broken i took it to a friends garage and he could not find the fault he rang and autoelectriction he know they changed the boot catch and electric motor and match it up with software and now it works at a cost of £200 all in Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 17, 2013 Share Posted September 17, 2013 How did they get the boot open, given that it was locked shut? Quote Link to comment Share on other sites More sharing options...
