AdBlock Warning
Blue4life64
Why Does My Temp Gauge Read -57C
5 posts in this topic
ive noticed after disconnecting battery my temp gauge now reads -57c ?
anyone else had this ?
any ideas ?
cheers
thats pretty random.
i had an issue with my Leon cupra r, i found that it would go to -257c when it froze over night.
i found that the sensor had come off when i was tinkering and the sensor was dangling in water when i use to clean it in one of the fog holders and didnt realise. not sure if thats the case or not. but hooked it back to the clip and it was fine.
Sounds like its not reading the sensor properly, try resetting the car with the battery disconnect again, and wipe the wing-mirrors down, specifically on the underside...
Check the sensor is still connected . This could be a default 'null' value.
This happens to my car when the battery is disconnected. After a few hours (or over night) it returns to normal. I assume its just a case of it self recalibration.
Unless it stays that way for a few days I wouldn't be overly worried.
Stu
