AdBlock Warning
Sign in to follow this
Followers 0
weejoe
focus zetec issue
9 posts in this topic
HI have recently picked up a Focus 1.8 Zetec, Im wondering if any1 can help! When i start the car when it fires up the rev counter goes straight to 7000rpm but the engine doesnt rev to it! And then after a few seconds will drop down to normal. The car drives normal etc. This has only happened twice in 2 weeks! Any ideas what it could be?
Have had this happening to mine also, usually on cold mornings. But I wouldnt see it as much of a problem as all my Dials shoot straight up for a second, then just level off... is it just the revs?
yup just the rev's.
Tricky one <_<
I know the focus has a history of dial problems, I have yet to have any (touch wood) but maybe this could be the start of it? maybe someone with more knowledge could confirm ;)
isnt this 'dial sweep' indicating a problem with a low battery?
Im not sure. All i know is its intermittent. it happened again today! When it happens its actually both the rev count and speedo that go round. I checked the speedo trick which showed no DTC errors. No sure if it could be the battery although when it happens the car doesnt start first time.
No, all the dials sweep with this not just the speedo. Id say its a fault on the instrument cluster.
I did the cluster test by holding the reset button and starting the car. It read none for DTC codes. But spose it could be the start of a cluster issue. But I hope not.
It'll be a cluster fault , the dealer should change it for £99.00 inc (ref watchdog).
Followers 0
