Bower Posted June 25, 2013 Share Posted June 25, 2013 Hey guys. Apologies in advance if this has already been asked, but I could not find it anywhere. I am looking for the exact size of Ford Fiesta mk7 62 plate pre MCA alloy size. I managed to find that the distance between holes is 4*108, but what is the size of the center hole? Besides, any of you tried fitting rims with a larger center hole and then adding the adjusting nuts onto it? Thanks in advance Quote Link to comment Share on other sites More sharing options...
ChrissH Posted June 25, 2013 Share Posted June 25, 2013 The ones on my Zetec are 15" - I believe the Titaniums are 16" Can't say about fitting rims with a larger center hole, but i'm sure that someone on here will be able to help! Quote Link to comment Share on other sites More sharing options...
Bower Posted June 25, 2013 Author Share Posted June 25, 2013 Yh, I am fully aware of the diameter of the rim, I am more interested in the fitment parameters. Quote Link to comment Share on other sites More sharing options...
Philf1 Posted June 25, 2013 Share Posted June 25, 2013 My Zetec S has 17" wheels and the centre caps are 55mm, that's the size of the DMB's I bought so guess the actual hole is about same. Quote Link to comment Share on other sites More sharing options...
sambooka Posted June 25, 2013 Share Posted June 25, 2013 The fitment is j7 4x108 as for the centre hole I would guess 55mm as above as for fitting alloys with a bigger centre hole I don't thing you can as the stud holes will be in a different place. J7 and 4x108 will get you the right alloys for the car Quote Link to comment Share on other sites More sharing options...
welshy_maverick Posted September 4, 2013 Share Posted September 4, 2013 The fitment is j7 4x108 as for the centre hole I would guess 55mm as above as for fitting alloys with a bigger centre hole I don't thing you can as the stud holes will be in a different place. J7 and 4x108 will get you the right alloys for the car exactly!! thanks!! with an allowable et/offset of anything 38 to 47.5 correct? Quote Link to comment Share on other sites More sharing options...
sambooka Posted September 4, 2013 Share Posted September 4, 2013 I believe so yes my aftermarket alloys are 42 and I've never had any problems and ford never said anything when it's been in for services 1 Quote Link to comment Share on other sites More sharing options...
welshy_maverick Posted September 4, 2013 Share Posted September 4, 2013 I believe so yes my aftermarket alloys are 42 and I've never had any problems and ford never said anything when it's been in for services Thanks, im looking to get these:- http://www.wheelbasealloys.com/alloy-wheels/team-dynamics/cyclone-code-red/black-red/17-inch I know they are not to everyone's taste but do you think they will fit? They are 17", the have at ET of 38. The only thing, which I just emailed the company about, it says "fits most 4 and 5 stud patterns"....how can it fit multiple stud patterns with only 4 stud holes? It doesn't say the image is for display purposes etc just sent them an email to check that they do fit a 4x108 stud pattern. weird think is the compatibility drop down menu on the website says they are not compatible with the fiesta, but a previous email from the site says they'll be fine. Just wanna make sure before I order then end up having to try and return 4 alloys and pay for postage!! Quote Link to comment Share on other sites More sharing options...
sambooka Posted September 4, 2013 Share Posted September 4, 2013 They will be fine not to my taste but each to there own and the fitting 4 and 5 stud is because you have to tell them which you want or I did when I got mine from that same company Quote Link to comment Share on other sites More sharing options...
