tommy1340millar Posted June 26, 2013 Share Posted June 26, 2013 2005 mk2 1.8 tdci estate. Started on Sunday, moved heater controls to hot. Worked for about 20 secs, then started blowing cold air. I searched for similar problems on internet. Removed stereo, no kink in temp. cable. Where is/are sensors? I do hope it's not the water pump (Car has been a wee bit noisy last couple of weeks) Quote Link to comment Share on other sites More sharing options...
IINexusII Posted June 26, 2013 Share Posted June 26, 2013 coolant topped up? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 26, 2013 Share Posted June 26, 2013 it could be either the heater matrix, or the resistor. Does it do this on all four heater settings? Quote Link to comment Share on other sites More sharing options...
tommy1340millar Posted June 26, 2013 Author Share Posted June 26, 2013 coolant topped up? Yep all ok there it could be either the heater matrix, or the resistor. Does it do this on all four heater settings? Yeah, the fan's ok, it just blows cold air regardless of fan speed or position of the temp. knob (I can hear the tone changing, so the temp flap is moving Quote Link to comment Share on other sites More sharing options...
artscot79 Posted June 26, 2013 Share Posted June 26, 2013 sounds like it may be the water pump with the engine hot can you see coolant flowing into the expansion tank and are all the hoses hot Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 26, 2013 Share Posted June 26, 2013 I would also consider the heater resistor.. Quote Link to comment Share on other sites More sharing options...
