Reversing Camera
19 replies to this topic
#16 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 18,986 posts
  • Name: James
  • Year: 2007
Posted 03 July 2013 - 08:05 AM
you would need to feed it back into the cabin, or at least into the trunking then down the boot seals and into the panel to click into the lights I suspect.
Have something to contribute?
#17 stevegtuk
stevegtuk
    Stevegtuk
  • True Ford Enthusiast
  • 564 posts
  • Name: Steve
  • Ford Model: MONDEO
  • Year: 2006
Posted 03 July 2013 - 08:32 AM
mines an mondy estate so was a pig of a job to get the wires through the rubber sleeve where the loom goes at the top of the door, but once that bit was done, the rest is fairly straight forward, just tuck it behind the trim round the edge of the car, or along the roof lining.
The numberplate cam is well worth it, as you can see it is very subtle so wont be abused or accidently caught by kids or other people walking past.
But like i said the only draw back is the light, if you have a dull light in the other plate light your ok, otherwise it looks very lopsided. I started off by adding  short strip of waterproof leds under the handle, but i ended up having trouble with it due to the small fiddly position it was in, so bought for some of these.
http://www.ebay.co.u...=item33681e5e91
I then drilled about 4 or 5, 3-4mm holes in the underneath of the handle and just pushed those in, if you get the right size drill bit you can just push them in from inside the handle and they sit snug. Then just wire them into the numberplate wire thats already there and your sorted.
The first pic is the original led strips i put on to give you an idea, I know it looks tatty but bare in mind you wont see them unless the tailgates open. The second is the view i got from the cam when i was parked in the garage to give you an idea of view (the yellow skittle is right up against the bumper with the towbar next to it, then there is a green skittle either end against the bumper under the position of the lights. the red skittle is 6foot behind the car in line with the towbar)
Yeah ok the garage is a mess :lol:
#18 FOCA
FOCA
    Feet on the table
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 03 July 2013 - 02:16 PM
Well it would only want powering when the reverse light is activated, like the camera would be. So I could use the same wire for each- I think?
AS far as the right channel, isn't it just a wire that goes into it? So I'm hoping it would go straight onto it lol
Why not have it switched on when driving normally, you could even have it connected to a PVR (personal video recorder) so it would capture incedents/ bad driving (other peoples!) etc in conjunction with a front-facing recording camera
#19 stevegtuk
stevegtuk
    Stevegtuk
  • 564 posts
  • Name: Steve
  • Year: 2006
Posted 03 July 2013 - 06:40 PM
yeah you could watch the idiot behind crash into the back of you, or the look on their face when they realise they havent left enough braking distance :lol:
#20 Brigante
Brigante
    Resident Ranter
  • 2,700 posts
  • Name: Charlie
  • Ford Model: Mondeo Titan X Sport 2.2 175BHP
Posted 08 July 2013 - 01:09 AM
in case its of use i did create a guide to fitting a rear view camera a while ago..
Not what you're looking for?
