bigjimmyauk
2001 Festa Reversing Light Problem
1 post in this topic
reversing light isn't working, check gearbox switch and wiring bulb connector is getting 12 volts when reverse is selected, ran a 12 volt led accross and works fine but attach a 5watt or 21 watt bulb and nothing happens. Also when you plug a bulb in you lose voltage down to zero between the 12volt switch wire and the earth. Anyone got any suggestions? Thanks :)
