Parking Sensor Fault
6 replies to this topic
#1 redfox9361
redfox9361
    Newbie
  • Budding Enthusiast
  • Pip
  • 6 posts
  • Name: adrian
  • Ford Model: mondeo 2009 titanium x auto tdi
  • Year: 2009
Posted 02 July 2013 - 12:30 PM
Hi, I have a 2009 mondeo titanium X tdi auto and the parking sensors are making a continuous noise, I think from the rear sensors. Anyone know whats wrong and can it be fixed. Thank you.  Redfox 9361. :(
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,976 posts
  • Name: James
  • Year: 2007
Posted 02 July 2013 - 02:08 PM
if they are factory fit, it sounds like there is a short somewhere causing the beeper to stay on.
Is this only in reverse or all the time?
#3 redfox9361
redfox9361
    Newbie
  • Pip
  • 6 posts
  • Name: adrian
  • Year: 2009
Posted 02 July 2013 - 06:19 PM
Hi Jeebowhite, beeper cmes on when reverse is engaged but stays on when drive is selected. I switch it off on dash.
#4 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,976 posts
  • Name: James
  • Year: 2007
Posted 03 July 2013 - 07:58 AM
sounds like somewhere there is a short out giving power to the sensors where it shouldn't, Start by checking that it has a decent ground connection and that the wires aren't frayed at all. You problably need to take the rear boot panel out and check the wiring behind it.
#5 minnis
minnis
  • 203 posts
  • Name: Mark
  • Ford Model: SEAT Ibiza ST 1.2 TSi
  • Year: 2011
Posted 03 July 2013 - 05:43 PM
Is this how they normally work?
Mine are on in reverse only, my Dad's (front and rear) are on in reverse, then on for a set amount of time in 1st, and my brother's (again, front and rear) are on in every gear when speed is below 6ish mph. I'm currently fitting some to my girlfriends car, when the rears will be on in reverse, and the fronts will be on when the brake lights are.
To cut a long story short, is the problem just that there us a continuous beep, or that it is staying on?
In response to the beeping, try cleaning the sensors. There may be a bit of dirt or something that the sensors are picking up. Also try and find the box, and make sure all the sensors are plugged in correctly.
#6 redfox9361
redfox9361
    Newbie
  • Pip
  • 6 posts
  • Name: adrian
  • Year: 2009
Posted 04 July 2013 - 09:24 AM
Hi jeebowhite, Thank you, bad earth,, problem solved.
#7 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,976 posts
  • Name: James
  • Year: 2007
Posted 04 July 2013 - 10:56 AM
Fantastic! excellent news!
Not what you're looking for?
