crimeblitz1
2010 Rear Ford Emblem Badge Replacement
12 posts in this topic
Hey guys,
not happy with my "carbon and red" ford overlays from dmb, I think the carbon effect looks cheap and like I bought it from Halfrauds so im going to get either plain black or metallic grey background ones instead.
Anyway, my rear original ford badge is missing the top dome layer which prevents the gel overlays sticking on properly so I need to replace that before I buy my new gel overlays and stick them on. Does anyone know the part number for a replacement original rear ford emblem badge on a 2010 Focus? There are lots of different ones on ebay and all with different part numbers claiming to be the right one. heeeeeeeeeeeeeeeeeelp!!
I'll have a dig on microcat for you later.
appreciate that thanks.
Should be Finis number 1528567 (also came up with number 1532603)
Easiest way to confirm is pop to a local Ford dealers parts counter and ask them to check by your registration.
I can recommend a black background, look good...
post-43271-0-42208700-1372830843_thumb.j
Stoney, are those two numbers both for the same part? They are the two common ones on ebay but I don't know which is the right one to order. The problem I have is my local dealer is A LOT more expensive on everything than any other dealer it seems to be so I don't really want to go down there. plus the last time I wanted something simple ordered, I double checked the numbers he gave me with those online and they were completely different, I wanted to order a full mat set and for the £39 he quoted it turns out the part number he was going to get me was just a set of rears or something so no real faith in them
One is for the estate version (1528567) and one is for the hatchback (1532603) version I believe.
It's because the one designed for the estate is like the MK2 badge and goes directly onto the hatch, whereas the one on the hatchback version goes onto the trim above the plate lights.
(more info on PM)
How do you remove your oem badges and fit the after market dmb ones?
they fit onto the front of existing badges.
So do you have to unclip the old ones then?
Or just stick them over the top of the existing ones.
Sorry for being dumb on this but never seen any up close
straight over the top of them, don't need to pull them off or anything.
Mine came this morning and fitted them. I first thought, they aint guna look good, but fitted them and have to say they do look good and you cant tell they are just stuck over the top.
