ccking2006 Posted July 8, 2013 Share Posted July 8, 2013 Hi all. I have just purchased a Ford Focus 2005 1.8 TDCI. I can use the key to get into the car but the central locking is not working. I have a key fob for the car and when i press the fob i can hear the the central locking box in the foot well clicking. I have checked all fuses I have oiled and WD'd the lock on the door and the central locking unit also the boot release catch is not working from inside of the car Quote Link to comment Share on other sites More sharing options...
jacksargent93 Posted July 11, 2013 Share Posted July 11, 2013 Have you tried re-programming the key? Quote Link to comment Share on other sites More sharing options...
ccking2006 Posted July 12, 2013 Author Share Posted July 12, 2013 is that were u turn it 8 times. yes wen i do this i get to the 5 turn and there is a beeping coming from the dash and wen ive done the 8 turns nothing happens Quote Link to comment Share on other sites More sharing options...
Dan62 Posted July 12, 2013 Share Posted July 12, 2013 . Quote Link to comment Share on other sites More sharing options...
pugsley82 Posted July 12, 2013 Share Posted July 12, 2013 re programed worked for me when had simular Quote Link to comment Share on other sites More sharing options...
jacksargent93 Posted July 12, 2013 Share Posted July 12, 2013 When you get that beeping to complete the re-programme you have to press a button on the key but I'm not sure which one - I know I aint much help haha Quote Link to comment Share on other sites More sharing options...
ccking2006 Posted July 13, 2013 Author Share Posted July 13, 2013 all fuses ok i can not fined the box to reprogram it pic my help me if any one has some no i did not not press a buttan on the key fob after i terned it 8 times i new there was some thiing i did not do lol Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 13, 2013 Share Posted July 13, 2013 Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds. Remove the ignition key. The locking control system is now in "learn mode" for the next 20 seconds and you should hear a chime to indicate this. During the 20 seconds press one of the transmitter buttons. The remotes signal and code number is learned by the locking module and is indicated by another chime. Wait until learn mode times out (20 seconds) or switch the ignition back to ON Quote Link to comment Share on other sites More sharing options...
ccking2006 Posted July 13, 2013 Author Share Posted July 13, 2013 ok i will give this a go today and i will get back to u thanks Quote Link to comment Share on other sites More sharing options...
ccking2006 Posted July 13, 2013 Author Share Posted July 13, 2013 ok tryed that and i get the bleeping but still nothing is going on only a slite clicking noise coming from the fut well wen i press the key fob buttons Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 13, 2013 Share Posted July 13, 2013 Sounds like your central locking relay has died then. Quote Link to comment Share on other sites More sharing options...
ccking2006 Posted July 13, 2013 Author Share Posted July 13, 2013 is this in the fuse box or in the foot well can u tell me whitch one it is and a pic if u have one so i can go to scrp yardand get one thanks Quote Link to comment Share on other sites More sharing options...
ccking2006 Posted July 14, 2013 Author Share Posted July 14, 2013 ok i found the fuse at the back of the fuse box it hade blone i wood like to say thanks for all your help :) Quote Link to comment Share on other sites More sharing options...
