Button Removal Help
salsheikh
 Share
guys, how do you remove the front/rear heated windscreen buttons? i tried but felt it was gonna break
Link to comment
would it be easier to remove the unit with the buttons inplace, there may be clips on the back and push out from the back
Link to comment
Remove the radio fascia and you'll see two screws.
Undo those and the panel will come forwards.
Unplug the cable from the button you want to remove and push the button out with your thumb from behind.
There are lugs on two sides of the button casing but are more for tension to block the buttons coming out by accident.
I'll put up a couple of photos for you shortly.
Link to comment
Corection on my previous message, the lugs do need a bit of a push to release them.
Press top one in with something like a paintbrush handle/screwdriver blade while putting pressure on the rear of the button so the button shifts forward a bit then repeat with the bottom lug-
The blanks just push out with a little thumb pressure.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
