salsheikh Posted July 10, 2013 Share Posted July 10, 2013 guys, how do you remove the front/rear heated windscreen buttons? i tried but felt it was gonna break Quote Link to comment Share on other sites More sharing options...
vince_13 Posted July 10, 2013 Share Posted July 10, 2013 would it be easier to remove the unit with the buttons inplace, there may be clips on the back and push out from the back Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 10, 2013 Share Posted July 10, 2013 Remove the radio fascia and you'll see two screws. Undo those and the panel will come forwards. Unplug the cable from the button you want to remove and push the button out with your thumb from behind. There are lugs on two sides of the button casing but are more for tension to block the buttons coming out by accident. I'll put up a couple of photos for you shortly. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 10, 2013 Share Posted July 10, 2013 Corection on my previous message, the lugs do need a bit of a push to release them. Press top one in with something like a paintbrush handle/screwdriver blade while putting pressure on the rear of the button so the button shifts forward a bit then repeat with the bottom lug- The blanks just push out with a little thumb pressure. Quote Link to comment Share on other sites More sharing options...
salsheikh Posted July 11, 2013 Author Share Posted July 11, 2013 cheers Clive Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 11, 2013 Share Posted July 11, 2013 Anytime mate. Quote Link to comment Share on other sites More sharing options...
