fordmondeogirl Posted July 11, 2013 Share Posted July 11, 2013 Hi, My partner and I have just bought a 2004 Mondeo 2l TDCI hatchback and there is a fault. 2 problems Lesser problem being that when the car is sitting idling every now and again the engine will judder as if it going to cut out. The more serious problem is that when the car is in 5th or 6th gear over 60mph and you give it some throttle the coil light will flash and you lose your revs & throttle altogether. As the car slows you also lose your power steering and have to bring your car to a halt on the hard shoulder to reset your ignition. We have an idea what the fault might be but I'd like a second opinion - can anyone help? Many thanks. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 12, 2013 Share Posted July 12, 2013 Sounds like you need to replace coil pack and HT leads for the latter issue, the former issue is probably an idle control valve issue, or MAF sensor. Both can be removed and cleaned and would be a good place to start oh and welcome to the forums :) Quote Link to comment Share on other sites More sharing options...
mintalkin Posted July 12, 2013 Share Posted July 12, 2013 coil pack and leads may be hard to find on a TDCI :) i would get any fault codes read as it could be anything playing up from a cam/crank sensor, injector, to the fuel filter, any codes stored will point you in the right direction,a common cause of cutting out is the cam sensor, check to see if its a black one as ford had problems with them and did a replacement which was coloured grey. 2 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 12, 2013 Share Posted July 12, 2013 lol... thanks mintalkin, my error! Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted July 13, 2013 Author Share Posted July 13, 2013 Thanks for your replies! The trader we bought it from is putting brand new injectors on it for us on Monday - then on Tuesday we are having it serviced by our long term and well trusted mechanic. I will keep you up to date with our progress. Lovely car in all other aspects - really enjoying driving it. Does anyone know also if there is an AUX input? My stereo says AUX but I can't find a jack socket to plug my mp3 player in and CDs are way too much hassle. Quote Link to comment Share on other sites More sharing options...
FOCA Posted July 13, 2013 Share Posted July 13, 2013 If you look in the glovebox you may find the connector for the aux input (i know - cds are so much hassle! ) The 2nd symptoms you are having is the car going into "limp home mode" this is where the ECU detects a problem and puts the car into a restricted mode so you can "limp home" - it tells you this is happening by flashing the glow plug light ("coil" shaped orange light)- this does not mean it has anything to do with the glow plugs, it may not have anything to do with the injectors, either -garages/ mechanics often blame injectors for almost everything- which may not be the case - limp home mode can be caused by many things including a faulty EGR valve (you should get it blanked), or a faulty sensor, or for many reasons I take it you got the codes read?- what fault codes came up? Is it a TDCI 130 with a vnt (variable nozzle turbo) and a pnumatic turbo actuator with a front mounted EGR? (pictures (of the engine) would help) Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted July 15, 2013 Author Share Posted July 15, 2013 I will hunt down the aux input tomorrow. The injectors have been changed today to brand new ford parts and the car is already running so much better. It is going to my own trusted mechanic for a full service and once over tomorrow. It badly needs an oil change and we think it's always had cheap supermarket diesel in it. The car has been super accelerated on the motorway (within the speed limit) and did not cut out once - no flashing error codes and the engine sounding much happier. It is a 2l TDCI 130 but that's all I know - I'm such a typical woman.Also the alloys are a complete mess! What's recommended - refurbs or replacements? Pics of the car and engine tomorrow when I've taken it for a bath haha :-) Quote Link to comment Share on other sites More sharing options...
FOCA Posted July 15, 2013 Share Posted July 15, 2013 I The injectors have been changed today to brand new ford parts and the car is already running so much better. It is going to my own trusted mechanic for a full service and once over tomorrow. . . .Also the alloys are a complete mess! What's recommended - refurbs or replacements? Just as a matter of intrest how much is this costing in total? I was going to get my alloys (early Ford - the lightest they made) professionally shot-blasted and powder coated (Fords paint does not last but that will) Trouble was they wanted £250 to do this - i could (just about) get a discounted set of new alloys or a nice set of alloys with tyres secondhand on eBay for that kind of money If you get a second set of wheels you can put snow/ winter tyres on them and use them for the winter - bonus is you wont mind so much if you bounce them off a kerb, pothole etc I hear a lot of nonsense about supermarket fuel online The Delphi injectors (all mk3 TDCIs 2000-2007) don't "like" modern low- sulphor fuel (produced after 2007)- the sulphor helped to lubricate the injectors/ etc - the sulphor was removed for ecological/ emissions reasons and replaced with a small amount (5-7%) of bio-diesel (veg oil) whether its the cheapest supermarket stuff or the most expensive "premium" brand - the car/ injectors were never even designed for it! in 2006/ 7,(or therabouts) Ford even released a statement saying their diesels could not run on more than 5% bio-diesel - modern pump fuel has upto 7% Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted July 16, 2013 Author Share Posted July 16, 2013 It has cost me a grand total of naff all for the injectors because I pulled the trader up on the car not being fit for purpose so he actually replaced them for free. I found my aux input in the glove box - thanks! :-) It's had a full service today and my own mechanic has confirmed that my new injectors are indeed brand new and working well. So it's just my alloys which I will sort as it's just a cosmetic issue - it looks like someone has been kerbing it regularly on the passenger side. So basically it doesn't matter which station I use to fill it up? How often should I put something like redex in? Thanks again for all your advice :-) Quote Link to comment Share on other sites More sharing options...
stooge75 Posted July 16, 2013 Share Posted July 16, 2013 how does he know theyre brand new?just outta curiousity and if they are,dont EVER put redex in it,or forte etc,UNLESS it needs it for mot etc. I was a fan of forte until last week when I got a £800 bill for new injectors. Diesel specialist said we shouldnt ever add any conditioner/cleaner unless it really needs it. He's been at it for over 35yrs so would trust him without question Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted July 17, 2013 Author Share Posted July 17, 2013 well how am I supposed to know that? I'm not a mechanic. They still have the sticker codes intact I guess. Whether or not they are brand new is irrelevant really anyway - they are working - that's all I need to know, I will not put treatments in then - thanks for the warning. Quote Link to comment Share on other sites More sharing options...
stooge75 Posted July 17, 2013 Share Posted July 17, 2013 👍👍👍 Quote Link to comment Share on other sites More sharing options...
Jos7000 Posted August 10, 2013 Share Posted August 10, 2013 As for the wheels, as you are in Lancashire, a friend of mine does wheel refurbs in and around the Preston area if that is any help? Personally, I fitted a set of Jaguar alloys to mine, which required a full set of different wheel nuts as the mounting holes have squared seats and fords are tapered, Mitsibishi ones work fine :D Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted August 10, 2013 Author Share Posted August 10, 2013 Preston is within travelling distance for the right price - what are we talking per wheel? Mine are a disgrace. Engine wise car is running sweet now - a fuel pump valve has also been changed and I have had no problems since. Yay! Quote Link to comment Share on other sites More sharing options...
Jos7000 Posted August 10, 2013 Share Posted August 10, 2013 I've dropped him a message, as soon as I know, I'll let you know :-) Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted August 11, 2013 Author Share Posted August 11, 2013 Much appreciated thanks :) 1 Quote Link to comment Share on other sites More sharing options...
Jos7000 Posted August 13, 2013 Share Posted August 13, 2013 Right then, just got off the phone, the prices are as follows... Upto 18" £150 per set of four 19" and above is £175 If you want chrome effect add £10 per wheel. All work includes repair and powder coating. If you only want half the set done, split the price, lol Generally speaking depending where you are the price would usually include removal and refitting and obviously collection :-D However he says if you are outside of his typical area, he would arrange a deal on the price with you directly. I hope this helps, if you want his details let me know. :-) Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted August 14, 2013 Author Share Posted August 14, 2013 Thanks for doing that for us! I will discuss it with my fella and get back to you - many thanks :) Quote Link to comment Share on other sites More sharing options...
Jos7000 Posted August 14, 2013 Share Posted August 14, 2013 No problem :-) Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted October 15, 2013 Author Share Posted October 15, 2013 Sorry I didn't get back to your fella about the alloys Jos. This car is giving me a worse headache since then and I'm sincerely ready to drive it into the nearby canal. Upon starting the engine I have no throttle! The time it kicks in varies from 15 seconds to 15 minutes!! I got yelled down at a busy petrol station yesterday for not moving when my engine was idling! Other than this fault the car runs great. I am totally skint at the moment! Does anyone have any ideas as to what may cause this? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 16, 2013 Share Posted October 16, 2013 when you say you have no throttle, you mean you can put your accelerator to the floor and the car proceeds to idle? If you try to drive the car on idle (gradually bring up the clutch) does the car remain to idle and does the accelerator behave itself? Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted October 16, 2013 Author Share Posted October 16, 2013 when you say you have no throttle, you mean you can put your accelerator to the floor and the car proceeds to idle? If you try to drive the car on idle (gradually bring up the clutch) does the car remain to idle and does the accelerator behave itself? Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted October 16, 2013 Author Share Posted October 16, 2013 Yeah I have the yellow engine light on and if I floor my throttle no response until it kicks in and yellow light goes off. You can sometimes raise the clutch slowly in first or reverse & that seems to do the trick but it doesn't work all the time :-( Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 16, 2013 Share Posted October 16, 2013 Ideally we need trouble codes to help, do you have a code reader? or can you do the trip computer trick? Quote Link to comment Share on other sites More sharing options...
fordmondeogirl Posted October 16, 2013 Author Share Posted October 16, 2013 Tell me the trick and I'll give it a bash. I'm currently stuck in nursery car park until the damn thing decides I can have my accelerator. I'm ready to cry :-( Quote Link to comment Share on other sites More sharing options...
