jacksargent93
Any Idea How To Fit These?
4 posts in this topic
There should be an adjustable bracket that comes with them
You would need a switch to control the on off.
Long story short, positive to piggy back on the engine sensors fuse. Negative to earth / battery negative. Then wire the sidelight switch to pin 14, and the positive / negative to the appropriate DRL light cables.
Its relatively straight forward, I found the hardest part was trying to find a positive to feed it!
