Ticking!!
5 replies to this topic
#1 Jamesdurrant
Jamesdurrant
    Newbie
  • New Member
  • Pip
  • 6 posts
  • Name: James
  • Ford Model: Fiesta Zetec
  • Year: 2002
Posted 13 July 2013 - 02:46 PM
For some reason I have a ticking noise coming from my 1.4 ford fiesta Zetec, it happens fairly frequently and when it does I lose a little bit of power my revs drop by say couple hundred. Is happens very quickly obviously but is rather worrying....... Ay ideas??
Have something to contribute?
#2 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,977 posts
  • Name: James
  • Year: 2007
Posted 15 July 2013 - 01:22 PM
have you the ability to check for error codes? also is the ticking rythmic or out of sync? also how long does the ticking last for? and do you have any scenario this is most likely to occur (for example, when revs exceed X or air con is on etc).
#3 Lenny
    Retired Moderator
  • 11,420 posts
Posted 15 July 2013 - 04:00 PM
Have you had you're fuel filter changed recently?
It may be blocked restricting flow
The clicking would then be your fuel pump pressure attempting to fill the resivour
But can't fill quick enough due to restrictive particals
Resulting in loss of revs/acceleration
Just my theory and always good to replace fuel filters anyways don't cost much and help maintain fuel economy
#4 FiestaZS90150
FiestaZS90150
  • True Ford Enthusiast
  • 518 posts
  • Name: Nicolas
  • Ford Model: Ford Fiesta 2013 1.0 Ecoboost Racing Red
  • Year: 2013
Posted 15 July 2013 - 05:08 PM
Happened to my girlfriends 1.4 tdci. Huh ford quoted 2700e for 4 new injectors and the repairs. Hahahahahah I changed out the orings and took out the injectors, had them cleaned professionally and then put then back In. Cost basically nothing lol. Okay this maybe ain't your problem. The signs of this were ticking rhythmic lly, and ticking faster at higher rev. This would be all the time. Then eventually after a while the car started to get eac problems ( would appear on the display). which basically didn't allow you to go above a certain speed, so basically loss of power.
If this is the problem I suggest you go too a small garage where they have the time to actually find out what the problem is. Cause at ford in my case they just changed everything so that they are sure to get the problem solved, supposedly lol. Oh and if you do have a 1.4 tdci the injectors on these cars are alot of money. 400e for one in my case.
But I think you should get a sound recording of it, an see if the sound comes from under the panel filter.
#5 Jamesdurrant
Jamesdurrant
    Newbie
  • New Member
  • Pip
  • 6 posts
  • Name: James
  • Year: 2002
Posted 13 August 2013 - 08:44 AM
Thanks everyone for your suggestions! Turns out it is a problem with the relay on the air conditioner unit!
#6 wullie1515
wullie1515
  • Budding Enthusiast
  • 132 posts
  • Name: William
  • Ford Model: Ford Fiesta Zetec S 1.0 Ecoboost
  • Year: 2013
Posted 13 August 2013 - 05:13 PM
If the alternator bearing has gone it can cause a ticking noise, and revs drop a little as if it has been put under load, for example putting heated screen on etc, whilst idling, my ford focus 1.8 was doing that even when no load and it recently packed in on me haha! Soo check and see its not the alternator making the noise :)
Not what you're looking for?
