My Black Fiesta Zetec S
91 replies to this topic
#31 b4zz
b4zz
  • True Ford Enthusiast
  • 998 posts
  • Name: Barry
  • Year: 2009
Posted 18 January 2014 - 12:44 PM
liking the s badge and think that will look sweet
Have something to contribute?
#32 D13 HPD 95
D13 HPD 95
  • Budding Enthusiast
  • PipPipPipPipPip
  • 1,682 posts
  • Name: Daniel
  • Ford Model: Fiesta mk7 1.25
  • Year: 2009
Posted 18 January 2014 - 09:49 PM
Cheers bud, will take pictures when its back on the car. :D
Sent from my SM-T310 using Ford OC mobile app
Any pics :)
#33 danzetecs1600
danzetecs1600
  • 163 posts
  • Name: Daniel
  • Ford Model: Fiesta mk7 zetec s
Posted 18 January 2014 - 10:00 PM
As long as its not raining, ill stick it on tomorrow and upload some pics. :D Hopefully itll look alright.
#34 danzetecs1600
danzetecs1600
  • 163 posts
  • Name: Daniel
Posted 19 January 2014 - 05:53 PM
Had time to give the motor a good clean today and then stuck the s badge back on. Heres the pics. :D
Might not be to everyones styling taste, but I quite like it.
#35 D13 HPD 95
D13 HPD 95
  • PipPipPipPipPip
  • 1,682 posts
  • Name: Daniel
  • Year: 2009
Posted 22 January 2014 - 08:39 AM
looks good i think :) might do mine in gloss black, if i colour code it you won't be able to see it haha, also do you know how to get the front and rear ford badges off the plastic panels? cheers dude
still waiting for time to do mine -.- won't be for like another 3 weeks ish now super busy at work -.-
#36 b4zz
b4zz
  • 998 posts
  • Name: Barry
  • Year: 2009
Posted 22 January 2014 - 09:20 AM
liking the s badge fella and looks like you done a good job on the clean up
#37 danzetecs1600
danzetecs1600
  • 163 posts
  • Name: Daniel
Posted 22 January 2014 - 10:38 PM
Cheers Dan. Sorry im not sure about the badges, when I painted my front grill, I just masked it over. Gloss black S badge will look good on ya blue car. Look foward to seeing some pics when done. :D
#38 Scotty09
Scotty09
    Member
  • PipPip
  • 12 posts
  • Name: Ross
  • Ford Model: Fiesta zetec s
  • Year: 2001
Posted 22 January 2014 - 11:26 PM
Looking good pal. Keep us updated! :)
#39 danzetecs1600
danzetecs1600
  • 163 posts
  • Name: Daniel
Posted 25 January 2014 - 08:47 PM
Have fitted an after market heated seat kit today, which works really well. Have also fitted my momo gear knob after spraying it red and black to match me car. Will take some more photos again tomorrow.
#40 danzetecs1600
danzetecs1600
  • 163 posts
  • Name: Daniel
Posted 22 February 2014 - 01:54 PM
Another update,
Have fitted new alloys and tyres,
Rallyflapz mudflaps,
And aftermarket rear parking sensors.
Heres a couple of pics for now,
#41 nickandlaura2011
nickandlaura2011
  • 70 posts
Posted 22 February 2014 - 03:11 PM
Hi what aftermarket heated seats did u buy and whats the outcome. What do they look like could u show a pic please
Sent from my C5303 using Ford OC mobile app
#42 Gazst170
Gazst170
  • 198 posts
  • Name: gary
  • Ford Model: st170
  • Year: 2002
Posted 22 February 2014 - 03:29 PM
Hiya danszetec 1600 ive got to say black and red looks very smart:rolleyes:
#43 danzetecs1600
danzetecs1600
  • 163 posts
  • Name: Daniel
Posted 22 February 2014 - 05:39 PM
http://www.ebay.co.u...=item3f28721987
Hi Nick and Laura,
This is the exact kit that I bought and installed in my car, and has to be the best mod I have done on any car ever. I also used these to get power to them.
http://www.ebay.co.u...=item35b3f1106b
#44 nickandlaura2011
nickandlaura2011
  • 70 posts
Posted 22 February 2014 - 06:37 PM
Thanks for that how did u do it did u take the seat covers off and stick them on then put the cover back on. Also how easy is it to wire up and what does it wire up to.
Many thanks Nick
#45 danzetecs1600
danzetecs1600
  • 163 posts
  • Name: Daniel
Posted 22 February 2014 - 07:37 PM
Firstly I removed both seats and removed enough of the underseat clips+seat back adjuster wheel and plastic sides until I could get enough of the seat cover loose that I could slide my hands underneath with the heater pad and locate it with its adhesive sides, (this was a bit fiddly)then using a suitable sized hole saw I drilled a hole for the switch in the side of the seat, then connected all the wiring and zip tied it to the underneath of the seat. I then wired the black ground/Neutral wires using crimps to some bolts that hold the gearstick linkages in place underneath the center console and then wired the red/ Live wires to the mini fuse taps using the through crimps supplied with them, and piggy backed one to the fuse that was supplying the spot lights, and one on the fuse suppling the rear wiper. I chose these circuits because they are only supplied with power when the key is in the ignition and turned on, which stops you leaving the car with them accidently left on. Also although they piggy back other circuits they don't affect the circuits. Took between 4/6hours to do. Has been fine ever since. Check out you tube for more installation guides. :D
Here is a pic of button on side of seat, had to use torch, as its dark outside, lol.1393096906025.jpg
Another thing when you put heat pad on back part of seat make sure the wires supplying the pad are closest to the bottom back part of the seat, and for the seat pad (the one you sit on)i put the wires suppling the pad around the front of the seat,so that you leave yourself with enough wire to reach the relay that you will zip tie underneath the seat. I also didn't have to trim the heat pads at all. Hope this helps, any probs just ask.
Sent from. my SM-T310 using Ford OC mobile app
Not what you're looking for?
