Guest Posted July 17, 2013 Share Posted July 17, 2013 Hi Guys, I'm looking to replace the buttons for the heated windscreens (back and front) and i'm having difficulty removing them, is there a plan of action i need to take? The buttons i currently have have worn away (being its a used car) so i wish to get them sorted. cheers! Quote Link to comment Share on other sites More sharing options...
JW1982 Posted July 17, 2013 Share Posted July 17, 2013 The easiest way is to remove the radio surround panel first. For the MK2.5 with the oval shaped radio this panel is fully clicked. Next you can remove the 2 screws of the switch panel and pull it out (the switch panel is also clicked). When the panels comes loose you can push the switches out from the back. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 17, 2013 Share Posted July 17, 2013 Any video showing how to remove the panel? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted July 17, 2013 Share Posted July 17, 2013 To remove the radio surround panel you just have to pull firmly. The best way is to start at the bottom of the panel and if the clips release themselves you can work upwards. Quote Link to comment Share on other sites More sharing options...
