2012 Focus Alarm
3 replies to this topic
#1 Llew
  • New Member
  • Pip
  • 2 posts
  • Name: Daniel
  • Ford Model: focus
  • Year: 2012
Posted 19 July 2013 - 11:25 AM
The alarm on my 2012 focus estate keeps going off during this hot weather. I assume that its the heat & over sensitivity that sets it off. What really worries me is what if it goes off when I am not around. Will it go off indefinitely or is there a cut out after a period of time.  Currently it seems to go off for about 30 seconds then stops, and restarts soon again. I am assuming that there is a cut off when it won't start all over again,- anybody know?
Have something to contribute?
#2 jeebowhite
    Resident Loon
  • Super Mod
  • 22,305 posts
  • Name: James
  • Year: 2007
Posted 19 July 2013 - 01:00 PM
Normally alarms go off anywhere between around 30 seconds to 5 minutes, and the alarm noise stops, the indicators may continue to flash for up to 15 minutes, however the alarm shouldn't persist for longer than this.
I would advise taking the car back to Ford, as the sensitivity should be reduced or any faulty part should be replaced under warranty.
#3 Preee
    Ford Fruitcake
  • 4,397 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3.5 | Fiesta Zetec Mk7
  • Year: 2015
Posted 19 July 2013 - 03:53 PM
To pin it down to the sensors , on swithcing ignition off , select to deactivate the sensors , then if it does not go off you know its a sensor fault.
Mine tends to trip in winter months if i have had the temp high and get out of the car quickly and then it triggers. , If i get out of the car and let a decent ammount of new air into the car it does not go off.
#4 Foci_st3
  • Budding Enthusiast
  • 353 posts
  • Name: D
  • Ford Model: MK3 Focus Titanium x
  • Year: 2012
Posted 19 July 2013 - 09:12 PM
Never had an issue with mine
Not what you're looking for?
