Power Fold Mirrors Via Remote
26 replies to this topic
#16 clubber
clubber
  • Budding Enthusiast
  • 109 posts
  • Ford Model: ST3
Posted 24 July 2013 - 05:29 PM
I thought 1 wire goes from the mirror plug pin 8
post-37776-0-41029400-1374600765_thumb.j
to the blue plug in the Driver Door Module (DDM), pin number 14
post-37776-0-96359500-1374600738_thumb.j
A 2nd wire goes from the new power fold switch/sensor switch, pin 3
post-37776-0-94434000-1374601320_thumb.j
to the black plug on the DDM, pin number 17
Have something to contribute?
#17 yunii
yunii
    yunii
  • True Ford Enthusiast
  • 752 posts
  • Name: yunii (nickname)
  • Ford Model: FOCUS TITANIUM-S
Posted 24 July 2013 - 05:39 PM
I think Thats correct, but you will need to enable via elm 327 on pdm/ddm, infact do this first.
Yunii
#18 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 24 July 2013 - 05:43 PM
Yunii
So only 2 wires then?
I have activated it already using ELMconfig.
Just waiting on the switch as the dealer ordered the wrong one.
#19 Tezza
Tezza
  • 164 posts
  • Name: Terry
  • Ford Model: Focus ST3
  • Year: 2009
Posted 24 July 2013 - 06:32 PM
Yes only 2 wires :)
And do you know the part number of the second switch he has ordered as that one could be wrong also
#20 Tezza
Tezza
  • 164 posts
  • Name: Terry
  • Year: 2009
Posted 24 July 2013 - 09:12 PM
did your car come with power fold mirrors if not where can i get them and how much?
I can get these  for around £200 for the pair if anyone's interested all you would need to do is use your existing colour coded cover and your indicator lamp
#21 alkyz89
alkyz89
  • 375 posts
  • Name: Aaron
  • Ford Model: focus zetec S
Posted 24 July 2013 - 11:06 PM
is that just for the mirrors, or the mirrors and switch?
what does the switch look like a were would it be positioned and what do i need to check first if i choose to go ahead with this mod??
cheers for the help and pics would be great if thats possible
#22 Tezza
Tezza
  • 164 posts
  • Name: Terry
  • Year: 2009
Posted 24 July 2013 - 11:14 PM
The price is just for the mirrors the switch would be a extra £38 for the one that fits in the door handle like this one in my video
http://s139.photobuc...652ad4.mp4.html
To find out if you can fit them you need to remove the door tweeter covers to reveal the mirror connection plug, on the passenger side you have to have 8 wires in the main door loom going to the grey plug that connects to the mirror
On the drivers side you have to have 7 wires going to the plug as you add the 8th and connect it to the DDM
#23 yunii
yunii
    yunii
  • 752 posts
Posted 25 July 2013 - 12:24 PM
is that just for the mirrors, or the mirrors and switch? what does the switch look like a were would it be positioned and what do i need to check first if i choose to go ahead with this mod??cheers for the help and pics would be great if thats possible
Also the switch needs to be modded as it won't fit in your existing loom as its different,as I noticed, but I swapped the circuit board out of it into your stock one, basically swap bits over,but first try in your switch loom.
Yunii
#24 clubber
clubber
  • 109 posts
  • Ford Model: ST3
Posted 25 July 2013 - 12:36 PM
This is the switch I bought, £21 delivered from Ford Parts UK
http://www.allcarpar...tch-assy-alarm/
#25 Teabags
Teabags
  • New Member
  • 50 posts
  • Name: DB
  • Year: 2009
Posted 26 July 2013 - 09:23 PM
How do you remove your existing colour coded covers.?
#26 Tezza
Tezza
  • 164 posts
  • Name: Terry
  • Year: 2009
Posted 26 July 2013 - 10:50 PM
Very easily :) just remove the glass ( pulls of and unclip the 2 connections for the heating elements)
You will see 3 tabs at the top on the inside that release the painted covers :)
#27 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
  • Ford Model: Focus MK2.5
Posted 27 July 2013 - 07:39 AM
So far, i've followed the steps suggested by the manual. After the first attempt, it seemed very easy. Plus you won't mess with the clips holding the mirror which seem fragile.
I moved the mirror all the way down and then used two screwdrivers to pull the two clips (middle and far-end) down. Then gently pulled the cover and it came right off.
Not what you're looking for?
