Sign in to follow this
Followers 0
cecil
clutch master cylinder
4 posts in this topic
hello
i'm a new member with fiesta finesse 2003.
great site - already found out about sump drain plug in the first minute.
i have lost clutch pedal - plastic actuator between pedal and cylinder broken. thought i would have ago at fitting new master. i am having a problem with refitting pedal return spring.
has anyone had this problem?
cecil
hello
cecil
what problem are you exactly having , can't get it on, can't remember where it fits , let us know.
Hi craggy
Thanks for replying
The problem was the tension on the spring made it difficult to align the clutch pedal pin.
After a number of attempts, i managed to do it. I just wondered if there is an easier way to fit the spring.
I am back on the road again now, but i am beginning to wonder if i should have fitted a new spring.
Is it possible to fit a new spring, without removing the pedal and master cylinder assembly?
cecil
Hi craggy
Thanks for replying
cecil
you should be okay with the old spring , i think you can replace the spring without removing the master cylinder , but i can't be 100% certain, i wouldn't personally bother putting a new spring on if everything feels okay.
Followers 0
