Air Conditioning Gas
Dan9014
 Share
Hi, i tested my air conditioning earlier using a thermometer and it came down to 8.3c but that was as far as it would go. Just wondering how cold should it be and would a re-gas bring it down any more?
If so how much gas would it need as there is no sticker underneath my bonnet!
Thanks in advance :)
Link to comment
As far as I'm aware, and I may well be wrong, when you get a re-gas they promise to get the temperature at least 10 degrees C below the outside temp - so with the heat we have had lately, your 8.3 degrees C sounds pretty good.
Link to comment
how did you test the a/c temp?
Link to comment
I used a digital thermometer which had a little prong on the end, i put the prong in the vent and got the temp :)
Link to comment
with the outside temp being what it is and the humidity you would likely need to have cold air going through the aircon radiator to have it drop any lower
Link to comment
Ok brill i know for a fact it hasn't been regassed in at least 2 years as i've had it for that long so wasn't sure but if that sounds ok then great it will save me some money.
Thanks for your help
Link to comment
did you close all but 1 dash vent and put the fans on full, you might find that it gives you a lower reading.
Link to comment
Yeah i did, that's what i was told to do
Link to comment
i was told that the core temp should be around 4 degrees.
Link to comment
Depends on the outside temp and humidity the aircon will cool at idle to a point the hot gas goes through the rad if theres no incoming air from the car moving then it wont cool enough thats why they wont test aircon below a certain temperature outside 10 degrees or so as the air is cool enough to give a false reading it can also take a few minutes to check window down aircon on cold fan set to recirculate give it a minute or two then fan off recirculate shut all bar one vent insert the thermometer and give it 5 mins max and youll get a better reading minimum temp is 5 degrees on standard non vss aircon pump the ti vct has the vss which regulates the gas to prevent freezing hence why it doesnt cycle on and off
Link to comment
Ok thank you all :) Big help
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
