AdBlock Warning
narbar
2005 Ford Ka Heater Blower Change?
Hi, I have a 2005 Ford KA where the heater blower makes a high pitched noise, higher the setting the worse it is. I was wondering if it needs changing or if there are any other problems which can cause it. Only other symptom, not sure if it means anything, is the car only seams to blow hot air.
Also if I do need to change it is it a hard job? thanks Dean
