Steve
Focus Diesel Dpf Cleaner - Club Discount
7 posts in this topic
Vehicle age combined with higher bio-fuel content in today’s diesel fuels is making DPF regeneration more difficult. Saturated particulate filters risk being rendered inoperable with costly replacement and in some instances, additional recoding of the engine management system the only resolution. AR6500 will help prolong the life of the entire emission control system and combat the adverse effects of stop/start driving.
AR6500 is a new and powerful blend of additives designed to safely clean the fuel system, combustion area and emission control system components such as the diesel particulate filter (DPF) and catalytic convertor, thus helping such systems regenerate naturally and prolong their usable life. AR6500 contains an exclusive combustion modification technology that bonds to and removes hydrocarbon particulates. Using the thermodynamic principle of catalysis the energy required to start the chemical reaction of combustion is reduced.
This enhances the energy output as the competing reactions to combustion are greatly reduced, if not eliminated. The active chemistry reduces the temperature threshold at which carbonaceous deposits can burn thus enabling them to burn off more readily. Molecule by molecule deposits are safely removed thus restoring any lost performance and/or efficiency of the diesel particulate filter and catalytic convertor.
AR6500 can be safely used on blocked systems or as a preventative treatment to ensure components continue to run at optimum efficiency. AR6500 is compatible with all DPF and CAT types and will not harm any of these components nor the fuel system, engine or turbo charger.
Features/Benefits:
  • Reduces hydrocarbon deposits
  • Aids passive regeneration of the DPF
  • Prolongs the usable life of emission control system components
  • Restores lost power and performance
  • Lowers harmful exhaust emissions
  • Increases diesel lubricity by 44% (SAE Tested)
  • Suitable for all diesel and bio-diesel fuels.
USAGE INSTRUCTIONS
Add a single 100ml bottle with a full tank of fuel every 5,000 miles or whenever cleaning is required.
A single 100ml bottle will treat between 50 and 80 litres of fuel.
If you use the discount code FORDCLUB you will also get discount. Click here to view more info
The code is not valid
this has been sorted.. had a typo in the code
For a modern product they totally messed up with the bottle, It would be a nightmare to put in tank, half will end up on side of car, thats why the latest fuel treatments have the long neck now.
Comes with a free funnel according to the product page
georgen likes this
And we all know how useful free disposable funnels are :D
