Richdot
Ford Focus 1.6 2008 Ti
Hi guys.
Unsure about this bought a 2008 1.6 titanium with 36.xxx miles on... I have never had a ford petrol before but it seems like there there is a very slight whine in 1st and 2nd I don't know if this is just a normal Ford noise as from what I remember my sisters 1.4 fiesta petrol gearbox is about the same? The noise happens when you select gear and accelerate say to 3k after around 3k noise is gone!
Hi guys.
May be worth getting the gear box oil changed mate,
I would say get it topped up but gear boxes don't have oil level indicators, so the only way to ensure its full is to drain it completely and refill to manufactures specification level for example 2.4ltrs
The manual will specify how much to fill and what spec of oil for example automatic transmission fluid Dexron III
Ok could try that yes. I mean the noise is not that bad so it sort of makes me think that it could be a normal noise.
I think usually if it is a whine from the gearbox the pitch of the whine changes when you change gear and it does not do that. So unsure might be normal normal of the engine or something :s
without hearing it its hard to say i can say theres no whine on mine so it could be an air leak from a vacume hose it could be so many things without knowing where its coming from its guess work
Sounds like it could be Rally spec ;)
The car has done 36k so don't think its anything serious. .. well hope not ha
Could be the tracking or the tyres making the noise and as the road noise gets louder at higher speeds you cant ear it.
I think it's more engine / gearbox noise that be a pure guess though hard to pin point. It's a very slight noise not loud or nothing like that.
if in any doubt get it checked out what might be nothing now could become a huge bill quite quickly
Had the car checked no problem has been detected.
