AdamC11
Numberplate Bulbs
http://www.ebay.co.uk/itm/T10-501-W5W-Can-Bus-NEW-NUMBER-PLATE-WHITE-LED-15-WATT-CREE-bulbs-MERCEDES-1-/141026765683?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20d5d9ab73
Cree are tip class bulbs,
Please note: when replacing bulbs for led,
Remove bulbs then turn on lights,
With lights ON
Plug in LEDs
Because LEDs are fixed polarity the may not illuminate when fitted first time
So you may need to rotate bulb 180 degrees then plug in again,
It will work the second time.
With lights ON
Plug in LEDs
you got a picture of those at night in a numberplate?
No mate,
I haven't purchased yet but anything cree won't burn out in a week,
And says there 15watt of light so 30watt of light is more than sufficient.
Don't underestimate the power of Cree ;)
I bought these ones for my fiesta as all of the LED point down so all the light was shining of the numberplate. Best/Brightest cheapy LED ones I have found....and trust me I have tried loads of them. If your budget it higher though I would love to see the difference in the ones that Lenny has suggested as for that money I would want the type that BMW have on some of their cars.....super super bright ice white light. If they are that good I would consider replacing mine. But the ones in the link below are the best ones I have found so far...
http://www.ebay.co.uk/itm/330871336034?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Just fitted Cree 501's in mine, they are really bright only issue is they don't shine directly down but slightly to the side, you can see in the photo below.
Got them off ebay £4.99 each but really quick delivery from this guy,
http://www.ebay.co.uk/itm/New-Cree-LED-Super-White-3w-T10-501-W5W-Car-Van-Bulb-Sidelight-Interior-Exterior-/300882289692?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item460dfb641c
I also put themin my reverse lights they are super bright!
Advantage with these is they intelligent so no problems with polarity, just plug and play.
I have just fitted a nother set in front sidelights and upgraded headlights to HID's so all my bulbs are properlywhite now.
Nice one Lenny. Sound a bit pricey but better than trying to butcher your stock ones which is what I have been considering.
Looks decent although I lucked out on some cheap fleabay jobbies that have lasted 2 cars lol.
The quality was crap, they didn't work at first and went off whenever the boot was shut or I went over a bump in the road, but I re-bent the contacts and they work perfect now lol.
Yes I've experienced this before too,
As result I spread the pins up to 45 degrees before inserting in to the sockets to ensure maximum contact,
Also
The way these full led units plug in outside of the sealed unit,
I'd recommend insulating the socket&plug connection with PVC tape to prevent water engress from blowing a fuse.
Just wondering if white led number plate lights are road legal in the UK? as i read somewhere that it shouldn't emit white light from the back as it may not pass its MOT? correct if I'm wrong, thanks and Phils lights look awesome mate! :)
Thanks Abdul. As mine is a new car no MOT for 3 years so no worries. I think if they projected backwards t=it might be a problem but as they shine down should be OK. If the police do stop me guess i'll just get a notice to put them right so not too worried.
