Removing Rear Wiper
StuartC88
 Share
I tried this yestetday. When I went to put the grommet in tho if I put it against the bodywork theres a gap between there and the glass. if I put it against the glass theres a gap between bodywork and grommet. Has anyone got any close up pics of how theres is done?
Link to comment
I removed my rear wiper on my Fiesta mk6, and once i finished there was a hole where the wiper should have been, you need to get a 'blanking plug' or something like that to block the hole. If this is what your on about anyway lol.
Link to comment
Hi StuartC88
Here are some pictures.
Its a 24mm outer, tried a 25mm today. Not much better.
Im awaiting a plastic grommet at the moment.
Please follow link:
http://s490.photobucket.com/user/AdamC11_Bling/library/Rear%20Wiper?sort=3&page=1
Cheers
Adam
where did u get it from?
Link to comment
did u take the rubber bit that was in the hole originally out or leave it in? when I put my rubber grommet over the hole it leaves a gap at the top between the grommet and the bottom of the window
Link to comment
I bought the grommets from Halfords.
Mine fits flush.
I removed the rubber inner where the wiper was.
The inner grommet is 19mm and the outer grommet is 24mm. I have poured water over the windscreen and no water has seeped through.
Cheers
Link to comment
I have 2 small gaps. 1 either side of outer grommet ill try post pics
Link to comment
Looking good StuartC88,
I will change mine to 25mm as im currently waiting for a plastic grommet.
Link to comment
what about the gaps either side of the grommet in the last pic is that normal? Plus it can be pulled out very easily :\
Link to comment
Thats fine mate. Mine looks the same currently.
As long as water doesnt leak in, its fine.
Its the risk you take with any rubber gromet, mines been on nearly a week and nobody has touched it. :-)
Link to comment
Ah thats gd then :). Ill maybe try and find something to seal it with
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
