16Vrhys
Air Bag Light On
6 posts in this topic
air bag lights on flashing code 12 , which means duff module , but last week it was also displaying a code which mentioned pre-tentioners but is not showing any more
having a look around the car today i noticed that the drivers side appears to have no pretentioner ?
passenger one is bolted up around where seat belt clips in , drivers side u can see where one would go , but theres wires underneath the seat or any thing?
2002 A052 ford fusion 2
The pretensioner of the driverside seatbelt is located in the B-pillar in the roll-up mechanism. The passengerside is located as you described. Why they use 2 different systems in the same car i don't know.
ahh thank you ! yeah even the seat has a spot for the pre-tensioner to go !
so more likely needing a new air bag controller? where abouts are they mounted? hope not a dash off job!
If i'm correct the controller is located underneath the plastic cover under the handbrake handle.
main air bag controller ??? if so then great , shouldn't be to hard to get at , thought they always up in dash somewhere!
Yep, it's that simple ;)
Just look at this pdf, it's A208 in the pic, it should be between the front fixing points of the front seats, underneath the plastic cover/console.
rcm3.pdf
And for the whole electrical scheme, it's the right scheme on this page (SRS):
SRS.pdf
Lenny likes this
