16Vrhys Posted August 9, 2013 Share Posted August 9, 2013 air bag lights on flashing code 12 , which means duff module , but last week it was also displaying a code which mentioned pre-tentioners but is not showing any more having a look around the car today i noticed that the drivers side appears to have no pretentioner ? passenger one is bolted up around where seat belt clips in , drivers side u can see where one would go , but theres wires underneath the seat or any thing? 2002 A052 ford fusion 2 Quote Link to comment Share on other sites More sharing options...
Gombal Posted August 9, 2013 Share Posted August 9, 2013 The pretensioner of the driverside seatbelt is located in the B-pillar in the roll-up mechanism. The passengerside is located as you described. Why they use 2 different systems in the same car i don't know. Quote Link to comment Share on other sites More sharing options...
16Vrhys Posted August 9, 2013 Author Share Posted August 9, 2013 ahh thank you ! yeah even the seat has a spot for the pre-tensioner to go ! so more likely needing a new air bag controller? where abouts are they mounted? hope not a dash off job! Quote Link to comment Share on other sites More sharing options...
Gombal Posted August 10, 2013 Share Posted August 10, 2013 If i'm correct the controller is located underneath the plastic cover under the handbrake handle. Quote Link to comment Share on other sites More sharing options...
16Vrhys Posted August 10, 2013 Author Share Posted August 10, 2013 main air bag controller ??? if so then great , shouldn't be to hard to get at , thought they always up in dash somewhere! Quote Link to comment Share on other sites More sharing options...
Gombal Posted August 11, 2013 Share Posted August 11, 2013 Yep, it's that simple ;) Just look at this pdf, it's A208 in the pic, it should be between the front fixing points of the front seats, underneath the plastic cover/console. rcm3.pdf And for the whole electrical scheme, it's the right scheme on this page (SRS): SRS.pdf 1 Quote Link to comment Share on other sites More sharing options...
