Can Anyone Help, With A Speedometer Problem
2 replies to this topic
#1 Southseacap
Southseacap
    Newbie
  • Members via FB
  • Pip
  • 2 posts
  • Name: Thomas
  • Ford Model: Focus
  • Year: 2004
Posted 09 August 2013 - 07:01 PM
Hi, l have got a 54 plate Ford Focus zetec.
But l have a problem with the speedometer, when l'm driving, the speedometer stops working. lt did only happen once in a blue moon, but now it happens most days.
ls it just a sensor or the main computer?????
Have something to contribute?
#2 Lenny
    Retired Moderator
  • 11,618 posts
Posted 09 August 2013 - 10:29 PM
Hi Thomas,
Welcome to the forum,
The new models such as yours operate on a CAN-BUS system its basically electronic signals sent through various parts of the car,
This means for your speedo it is not mechanically operated like cars used to be.
So the speedo needle is not directly connected to the speed sensor.
Resulting in it being one of two items either the sensor or the speedo cluster,
One way of finding out by yourself is:
If you look up on accessing ford secret menu,
You can access a digital speedo that will display in the centre screen between your tacho and speedo,
Drive the car with this digital speedo on display,
Then look at the digital speed reading when the needle drops.
If the digital speed also drops,
Then I reckon its your speed sensor that needs replacement.
But
If your digital reading stays constant while the speedo needle drops
Then unfortunitly its your cluster requires replacement.
Hope this helps mate,
#3 Southseacap
Southseacap
    Newbie
  • Members via FB
  • Pip
  • 2 posts
  • Name: Thomas
  • Ford Model: Focus
  • Year: 2004
Posted 13 August 2013 - 07:52 PM
Many thanks for the details, any idea as to where the motion sensor would be.
Today the needle dropped 3 times in just 5 miles, so it seems to be getting worse.
Not what you're looking for?
