dezwez
Focus Towbar Wires
hi can you just wire the tow bar in to rear lights or is this a new type of wiring they use on the mk 2.5 thanks
I guess you probably could , but O/S in the boot behind the panel i believe is the harness.
Don't forget about the wiring PDF i put up , it will help guide you
Yes they are , but your not fitting LED's in there are you , you will just be parrallel wiring to them.
I added to first post Dez , but remember i put up the Mk2.5 full wiring manual , it may help
yes I will get a copy of that thanks:)
just about to take a look at the Guide to ELM 327 and FF2 setup and wiring
in your guides
How are you enjoying you new car Dez?
Yes the ELM will enable you to add some extras , its very good
I tapped mine just before the plugs for the lights. I tried the big ol' plug behind the carpet but couldn't be 100% sure what was what.
If I have chance tomorrow, I'll try put up some pics.
I did go for a bypass relay. However, my LED light board doesn't draw enough current to trigger the indicator buzzer :D
