Air Filter Change Problem
1 reply to this topic
#1 leegoacher
leegoacher
    Newbie
  • Members via FB
  • Pip
  • 2 posts
  • Name: lee
  • Ford Model: fiesta
  • Year: 1997
Posted 11 August 2013 - 06:21 PM
I have a Mazda 121 basically the same as a fiesta mk 4 I have a standard air filter in box the air inlet sensor is housed in the air filter box when I want to put a cone filter on but will have nowhere for the sensor to go with put causing turbelance any ideas ( tube from the engine inlet has a metal casing with a chip connected with the sensor to the air filter box) will try and get pics thanks in advance
Have something to contribute?
#2 FOCA
FOCA
    Feet on the table
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 12 August 2013 - 11:57 PM
On some cars K&N etc make kits with pipes/ hoses to refit the MAF sensor
In general the cone filter is a waste of time - it loses power because it draws warm air from under the bonnet (cooler air = more oxegen per cc = more power) and the most it achieves is more noise
Heat sheilds and cool air intakes do not work if the cone filter can draw any warm, underbonnet air
A lot of manufacturers now make encapsulated cone filters now (BMC, pipercross(viper)) to combat this problem
Fully encapsulated pipercross viper cone filter/ induction kit -
More info -
http://www.europerfo...induction-kits/
BMC cda (carbon dynamic airbox) -
http://www.bmcairfil...rd_pr3_4_1.aspx
Even so often the stock airbox outperforms these - this is because the stock airbox is often "tuned" or "matched" to the engine to boost torque a little (the aftermarket "performance" filters are not)
You may be better fitting a panel filter from K&N or pipercross -
http://www.ebay.co.u...#ht_2927wt_1141
http://www.ebay.co.u...53#ht_976wt_932
Not what you're looking for?
