darkninja462
Fog Light / Reverse Light Rules & Regs
6 posts in this topic
Anyone know the rules and regs on changing your fog lights before its an MOT fail.
Want to make sure its right before spending money onsomething that will make it fail MOT
Regards
-Ninja
What you changing them to? As far as I know as long as they work and are right colour they should be OK.
In what way are you thinking of changing them?
Front fog lights are not tested on an MOT.
The only way you may have trouble is if you convert them to drl's which is not permitted by law unless you disconnect them from the fog light switch, change the bulbs to led and ensure that they dim or switch off with side/main lights.
Well from I have seen there are three versions of the image attatched, a clear crystal, and then a black clear, and then a smoked crystal. I didn't know if there was any law on how much they are tinted, I'm specifically looking for slighlty smoked (If its legal) as it will suit the colour of my car (Magnum Grey).
Regards
-Ninja
post-46170-0-59217400-1376950496_thumb.j
They will be fine however the above has changed as of this year i woute
Products on the lens or light source which obviously reduce the lights intensity or change its color will be a reason for fail this spplies to front and rear position lamps stop lamps directional indicators and fog lights
