Support the club!
Focus Dash Problem
8 replies to this topic
#1 tommyvb
tommyvb
    Newbie
  • Pip
  • 3 posts
  • Ford Model: Focus Zetec 1.8
Posted 05 April 2009 - 05:33 PM
Hello all,
My girlfriend has a focus on a 1999 plate i think its a 1.8 zetec
and she has a problem with her speedo,
now and again it wont work, she'll be drivign but no speedo working, this also leads to the car stalling/engine cutout when slowing down at junctions/round abouts etc etc ...
she had it in garage a few times an the mechanics rather say its sorted or theres nothing wrong.
But this only happens a few times, when the speedos not working she re-starts the car and most of the time it will work.
i personally think there maybe a loose connection behind the dash or a mucky/corroded connection. thats why it wont be working 100% but with the car cutting out that baffels me lol.
so thats why i come on here and ask if anyone knows anything about this problem and could help me..
Many Thanks and if anyone knows anythings please reply or email me and let me know.
all information is very very much appricated ..
thanks
#2 w2575
w2575
  • 33 posts
  • Ford Model: Focus mk2
Posted 05 April 2009 - 05:41 PM
Erm it could be a combination of things but in my experience it sounds either to be your battery on the way out , test this with a multimeter you should get 12v ! or it could be the alternator , the reason why i dont say its the dials is because you mentioned cutting out !
#3 tommyvb
tommyvb
    Newbie
  • Pip
  • 3 posts
Posted 05 April 2009 - 05:45 PM
Hello mate,
Ahhh thanks for that advice, so you recon it could be a new battery needed..
When i say it cuts out i mean like when slowiing down to junctions and roundabouts it cuts out, and has to be restarted.
i made sure its not my Girlfriend stalling lol its the car..
so what else do you recon
#4 craggy
craggy
  • 61 posts
  • Ford Model: mondeo 2.0 tdci ghia x
Posted 05 April 2009 - 05:50 PM
sounds more like a faulty speed sensor , which can cause the problems your having
#5 tommyvb
tommyvb
    Newbie
  • Pip
  • 3 posts
Posted 05 April 2009 - 05:54 PM
Thanks for your advice aswell mate.
So what you recon should be done.
i know your saying a new speed sensor. would that be around near the wheels to monitor the speed of the wheels and give you your speed on your dash,
what ya think about the cutting out issue
#6 dezwez
dezwez
  • PipPipPipPipPip
  • 3,002 posts
  • Name: Derek
  • Ford Model: focus estate 1.8
  • Year: 2002
Posted 05 April 2009 - 06:35 PM
the focus has an electionic speedometer with a speed sensor fitted to the transmission in
place of the older speedometer cable drive pinion.The speed singnal passes to the instrument panel vie the engine management
E C U. which also uses the speed signal for fuel system-relateded calculations.
so i would take a look at this speed sensor see if you can swap one with someone just to try it ;)
#7 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,330 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 05 April 2009 - 06:39 PM
i would say the speed sensor its a known problem and is located on top of the gearbox and held in place by a location pin.
#8 SierraYankee99
SierraYankee99
  • 859 posts
  • Ford Model: Ford
Posted 05 April 2009 - 07:24 PM
Unless its the MTX-75 gearbox then its held in with a torx screw and costs 3 times as much as one for the IB5 box
#9 sam1986uk
sam1986uk
    Member
  • PipPip
  • 21 posts
  • Ford Model: Focus
Posted 03 June 2009 - 09:05 PM
Probably the speedo sensor.
I believe it was on TV programme "Watchdog".
It is a common fault. One viewer said it can be temporarily fixed by spraying WD-40, but this is not a perminant fix though.
