mikeb185 Posted August 22, 2013 Share Posted August 22, 2013 Hi i have just purchased some genuine rear brake pads to replace the poorly fitting aftermarket ones that are currently on there. The genuine ones have a self adhesive pad on one side, and are completely different to the ones on their! Anyone know how to fit them correctly? Cheers Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 22, 2013 Share Posted August 22, 2013 They fit the same to be honest, the pads sit tight and the adhesive just helps to reduce vibration, there is also a 'spindle' on there that should assist in this also. Quote Link to comment Share on other sites More sharing options...
mikeb185 Posted August 22, 2013 Author Share Posted August 22, 2013 the ones on there rattle very loudly over every little bump in the road! Quote Link to comment Share on other sites More sharing options...
wase16ll Posted August 22, 2013 Share Posted August 22, 2013 as said, the self adhesive pad is just for anti-squeal/vibration, so no need for copperslip on back of pads... just fit the pads to the carrier and slide caliper over, when brakes are pumped up the pads will adhere to the caliper side.. Quote Link to comment Share on other sites More sharing options...
mikeb185 Posted August 22, 2013 Author Share Posted August 22, 2013 cheers! changed a fair few pads in my time but never seen any with sticky backs before! Quote Link to comment Share on other sites More sharing options...
mikeb185 Posted August 22, 2013 Author Share Posted August 22, 2013 urgent question! does the sticky pad go against the piston or is it the one with the spring on top??? the piston has two holes in but the pad pins are too widely spaced to fit in them??? Help please Quote Link to comment Share on other sites More sharing options...
mikeb185 Posted August 22, 2013 Author Share Posted August 22, 2013 the brakes are apart please help!!!!!!!!!!! lol Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 22, 2013 Share Posted August 22, 2013 the sticky pad) goes against the caliper, and so yes, I believe they should go against the piston. If your unsure, take the other wheel apart and look at the formation and mirror it Quote Link to comment Share on other sites More sharing options...
mikeb185 Posted August 22, 2013 Author Share Posted August 22, 2013 cheers, but on the piston there are 2 holes and on the pad there are 2 bits that look like they should fit into the piston but dont fit???? Quote Link to comment Share on other sites More sharing options...
wase16ll Posted August 22, 2013 Share Posted August 22, 2013 long time since ive done focus rear pads, cannot remember what they're like... so what do you mean by two holes in piston i take it the new pads are identical to the old Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 23, 2013 Share Posted August 23, 2013 You can just take those little poles off, and just fit it flat? Quote Link to comment Share on other sites More sharing options...
