mrgoodfellow
Front Fog Lamps
Ive got a fusion 2 and would like to fit front fog lamps to it, there seems to be an unused multiplug running down the side of the radiator does anyone know if this is for the foglamps? and is the wiring there for the switch to plug into.
thanks in advance
mark
Hi Mrgoodfellow the plug you see is a factory fitted fog light loom connector which runs all the way to your light switch in the cabin once you install your new fog lights you need a loom that connects from the fog lights to the fog light connector on the rad the cable can be picked up from ford and you may need a new light switch that incorporates front fog light operation
