! Guide ! Installing A Sub Box To Mk7
75 replies to this topic
#61 Lasher
Lasher
    Newbie
  • Members via FB
  • Pip
  • 2 posts
  • Name: Liam
  • Ford Model: feista
  • Year: 2011
Posted 22 July 2013 - 06:31 PM
I control mines from the dash radio.
In the sound menu you can change the bass from -7 to +7
As well as "middle" and "treble"
Yeah that's what I thought it would be like but I thought there might be a separate option for the sub itself if you see where im coming from ?
Have something to contribute?
#62 wickenss
wickenss
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: roy
  • Ford Model: Fiesta
  • Year: 2012
Posted 26 May 2014 - 09:22 PM
When you push the cables into the multi block how do you get them to stay in? Doesn't seem very secure. Nice tutorial please reply.
#63 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,762 posts
  • Name: James
  • Year: 2007
Posted 27 May 2014 - 11:37 AM
multiblocks normally have a screw to tighten to hold the wire in place.
#64 vettienbusta
vettienbusta
    Newbie
  • Budding Enthusiast
  • Pip
  • 2 posts
Posted 19 June 2014 - 09:11 PM
Hi. Does the stereo have the jacks to plug the amp straight in or do I need some kind of adapter. Thanks
Vettie
#65 Lenny
    Retired Moderator
  • 10,827 posts
  • Ford Model: Focus ZetecS
Posted 09 February 2015 - 05:35 PM
Few sub installation items for sale here: http://www.fordowner...ade-items-sale/
#66 Lenny
    Retired Moderator
  • 10,827 posts
Posted 09 February 2015 - 05:37 PM
Vettie
You will need a low level RCA output adaptor such as this: http://www.ebay.co.u...E-/270662823340
#67 JustCallMeTom
JustCallMeTom
    Newbie
  • Pip
  • 3 posts
  • Name: Tom
  • Ford Model: Fiesta Mk7
  • Year: 2009
Posted 27 February 2015 - 01:02 AM
Hi all,
I have wired my sub and amp in the same fashion as this, however i am getting some interference from somewhere. if i am not playing any music, there is a constant noise coming from the sub, and if i indicate or even flash my lights there is almost a heartbeat sort of beat from the sub. Could anyone tell me what could be causing this? I bought both sub and amp second hand, but the wiring kit was from motorworld and is an 8 gauge set.
Thanks!
Tom
#68 GillyShack
GillyShack
    Member
  • PipPip
  • 28 posts
  • Name: Gillian
  • Ford Model: Fiesta Edge 1.25
  • Year: 2011
Posted 27 February 2015 - 08:29 AM
Check where your remote is, chances are you're picking up interference from there.
Remember also don't run your RCA's directly beside your power cables down the side of the car, it takes longer but you're better running them down opposite sides of the car! That saves noise too. And of that still doesn't work then you can get noise suppressors that will cancel out the noise!
#69 JustCallMeTom
JustCallMeTom
    Newbie
  • Pip
  • 3 posts
  • Name: Tom
  • Year: 2009
Posted 27 February 2015 - 12:00 PM
Ah okay then thanks! I'll try that and repost!
#70 JustCallMeTom
JustCallMeTom
    Newbie
  • Pip
  • 3 posts
  • Name: Tom
  • Year: 2009
Posted 27 February 2015 - 12:01 PM
Should I run the remote down the same as the RCA cables or power cable??
#71 Lenny
    Retired Moderator
  • 10,827 posts
Posted 27 February 2015 - 05:35 PM
Same side as the power cable,
I recommend a ground loop isolator to eliminate interferance see link: http://www.ebay.co.uk/itm/251215258169
It filters the audio feed and removes any spikes from the negative line.
#72 NL-ST
NL-ST
    Newbie
  • Pip
  • 2 posts
  • Name: NL
  • Year: 2015
Posted 01 March 2015 - 12:41 PM
Has anyone used on of these RCA adapters with Remote/ Power out ?
http://www.ebay.co.u...=item566e4ba76b
Am I right in thinking that with this there would be no need to remove the headunit & the Power & Remote cables from the adapter could be wired up directly to the AMP (which will be in the boot with the sub) ?
And the speaker connection taken directly from the rear speakers ?
ONLY will need to run the POWER cable for the AMP to the battery
#73 Lenny
    Retired Moderator
  • 10,827 posts
Posted 01 March 2015 - 02:17 PM
Yes thats correct no need to remove headunit,
This perticular model does need a 12v feed; for this you could fit a piggy back mini blade fuse adaptor to the passenger glove box on a fuse which becomes live at ignition,
Just need power cable from battery and RCA from this box to your amp,
Audio cable between amp and sub i recommend vibe flatbass 13AWG
Im currently selling that aswell as some amp power cables etc see link:
http://www.ebay.co.u...=1&_ipg=&_from=
#74 NL-ST
NL-ST
    Newbie
  • Pip
  • 2 posts
  • Name: NL
  • Year: 2015
Posted 01 March 2015 - 02:32 PM
Great - I think I will be placing a order........
For the 12v feed from the adapter, surely I could connect to the Power terminal on the AMP (where the main power cable connects) ???
Same for the earth (of the amp) ???
Thanks for the link for the power cables BUT have already got everything which I have removed from my last car........
#75 Lenny
    Retired Moderator
  • 10,827 posts
Posted 01 March 2015 - 03:15 PM
You could splice them in with the feeds directly from battery while fitting an in-line fuse to protect the low level rca adaptor
It may say amperage on the box itself im guessing 10amp
Not what you're looking for?
