Belt Noise
18 replies to this topic
#16 Alec J
Alec J
  • 106 posts
  • Name: Alec
  • Ford Model: Focus ST3
  • Year: 2007
Posted 03 September 2013 - 01:51 PM
Finally got round to fitting a new belt. The smaller belt running the aircon compressor didnt seem to be the issue, it was the larger belt.
Changed the larger belt which cleared my issue when we started and tested it. I drove home and to my grief the noise is back!
Could this possibly be the tensioner at the top that you have to slacken to get the belt off? If so how can i test it as looking around they are about £50+ and dont fancy changing it if its not that.
Any other ideas as to what it could be?
Alec
Have something to contribute?
#17 vibeone
vibeone
  • 248 posts
  • Name: Mark
  • Ford Model: Focus MK2.5 2.0 TDCI
  • Year: 2009
Posted 03 September 2013 - 03:58 PM
Alec
As previously stated - It could be anything on the belt.  Start with the cheapest, and move on until you nail it.
If you're passing, you're welcome to my old tensioner - it is old, and not in the best nick, but when it was removed, it turned out it wasn't the issue (was the crank pulley on the engine).
#18 Alec J
Alec J
  • 106 posts
  • Name: Alec
  • Year: 2007
Posted 03 September 2013 - 09:09 PM
Haha ill be ok,
Whats the best way to check each thing.. just take the belt off and rotate them? Would they make noise?
#19 vibeone
vibeone
  • 248 posts
  • Name: Mark
  • Year: 2009
Posted 03 September 2013 - 10:16 PM
Sadly not - you can never match the load put on the pulleys. It's a case of replacing a bit at a time.
A ford dealer did a few bits (even putting bits on, removing if it wasn't the fault, and not charging me), but they didn't bother with the crank pulley for some reason
Took it elsewhere and as I said - the thing fell to bits as it was removed.
Bite the bullet and go for it. I'd start with the crank pulley because it's fairly cheap, but that's just me
Not what you're looking for?
