jps Posted August 31, 2013 Share Posted August 31, 2013 Soft brake on my 2006 2.2 tdci Mondeo had brake fluid changed 5 month ago and full service . The disc and pads have only done 12,000 miles .is it normal on Mondeo to have soft brakes or is it because of cheep pads .the brakes were soft before the fluid change Quote Link to comment Share on other sites More sharing options...
stooge75 Posted September 1, 2013 Share Posted September 1, 2013 your master cylinder-are you sure the seals are ok?any white crud behind brake master cylinder etc? Quote Link to comment Share on other sites More sharing options...
jps Posted September 3, 2013 Author Share Posted September 3, 2013 Will check out everything and get someone else to drive the car and get his verdict thanks Quote Link to comment Share on other sites More sharing options...
BOF Posted September 4, 2013 Share Posted September 4, 2013 Firstly, what kind of soft do you mean? Do you mean the pedal sinks towards the floor (soft brake pedal, even when stationery) the pedal sinks towards the floor (soft brake pedal, but only when stopping vigorously from high speed) braking takes a bit of time to get going (when stopping, you press the pedal and initially there is little response, but eventually something happens; sort of the opposite of 'grabby', but the overall effect might be the same if you overcompensate) I've found that the brakes have a tendency to 'grabby', so the opposite of 3), but it seems more pronounced on some than others (brake pad material???). ...Soft brake on my 2006 2.2 tdci Mondeo had brake fluid changed 5 month ago and full service . The disc and pads have only done 12,000 miles .is it normal on Mondeo to have soft brakes or is it because of cheep pads .the brakes were soft before the fluid change ...are you saying that the brake characteristic was exactly the same before and after the fluid change? Are you also saying that you know cheap pads were used? Quote Link to comment Share on other sites More sharing options...
jps Posted September 4, 2013 Author Share Posted September 4, 2013 It takes a lot to slow the car down at high speed .long pedal travel . it reminds me when you have new pads and they need bedded in and had brake fluid changed and made no different .I have had the car for a year , bought the car from a garage they changed the front disc and pads for the m.o.t before I bought the car Quote Link to comment Share on other sites More sharing options...
stooge75 Posted September 5, 2013 Share Posted September 5, 2013 Take it to a good mechanic mate. It wont take long for him to find out whats wrong Quote Link to comment Share on other sites More sharing options...
