D13 HPD 95 Posted September 3, 2013 Share Posted September 3, 2013 Could any one help me trying to find a fuse which is an ignition live switched live, so when i then the ignition on my drls come on but i dont want to connect them to a 60A fuse so can anyone tell me what fuse below is an ignition on please??? Quote Link to comment Share on other sites More sharing options...
sambooka Posted September 3, 2013 Share Posted September 3, 2013 Why not test the port for f25(drl) to see if its live and just use that it should be ignition live either that or use the 60a one you found and fit an inline fuse 1 Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted September 3, 2013 Author Share Posted September 3, 2013 Thank you i will check Quote Link to comment Share on other sites More sharing options...
E5GDM Posted September 4, 2013 Share Posted September 4, 2013 Run it to the 60A fuse, just put in a separate fuse to the required amperage on the DRL's feed. Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted September 4, 2013 Author Share Posted September 4, 2013 Ok the fuses i thought were ingnition live arnt ?? And have voltage supplied to them 24/7 so i move on does anyone know where an ignition live cable is?? Please Quote Link to comment Share on other sites More sharing options...
