Can't Start The Engine,urgent Heeeelp,please
limp mode
30 replies to this topic
#1 andysvision
andysvision
  • Budding Enthusiast
  • 144 posts
  • Name: Andi
  • Ford Model: Focus 2.0 TDCi
  • Year: 2006
Posted 04 September 2013 - 06:55 PM
Heeeeelp i have a Ford Focus 2.0 TDCi,im getting mad,i was just making a short tour in my town with my family,when we were turning home just 500m from my house everything went on,on my dashboard and a message saying:engine system failure or something like that,than the message acceleration decreased,i guess this i the limp mode :( but what happened is that i turned of my car and than i tryed 5 times to turn it on but no,i cant..please help what can i do,what may it be,is urgent :(
Have something to contribute?
#2 wase16ll
wase16ll
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Ford Model: granada
  • Year: 1992
Posted 04 September 2013 - 06:58 PM
is engine turning over
#3 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 04 September 2013 - 06:59 PM
if it is, so many possibles, you really need codes read to point you in right direction
#4 andysvision
andysvision
  • 144 posts
  • Name: Andi
  • Year: 2006
Posted 04 September 2013 - 08:31 PM
but i cant even start it up to take it to any garage to read the codes :( any posible way to make it start up?thanks
#5 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 04 September 2013 - 08:36 PM
without knowing whats wrong, not really
think your only option is to call someone out
#6 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 04 September 2013 - 08:45 PM
could try bleeding the fuel..might be enough to get it running
#7 andysvision
andysvision
  • 144 posts
  • Name: Andi
  • Year: 2006
Posted 04 September 2013 - 08:59 PM
hmmmm i thought maby if i unplug the battery for some minutes maby it resets the error codes for some minutes?
#8 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 04 September 2013 - 09:05 PM
you can try, but codes will stay till cleared
#9 andysvision
andysvision
  • 144 posts
  • Name: Andi
  • Year: 2006
Posted 04 September 2013 - 09:32 PM
Hel
 i just did the dashboard trick and i got this DTC codes
D147
D900
E197
E200
A103
Any clue?Thanks
#10 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 04 September 2013 - 10:19 PM
dont have those codes to hand, but did a search and all appear to be invalid data or data interupted...
2 refer to vehicle speed and odometer...maybe speed sensor failed.
2 refer to security.....maybe an immobiliser problem
maybe a power interuption somewhere...check the fuses, battery connections, earth leads etc
#11 andysvision
andysvision
  • 144 posts
  • Name: Andi
  • Year: 2006
Posted 04 September 2013 - 10:59 PM
so what you think ,does this sound like an expensive or cheap problem?thanks
#12 wase16ll
wase16ll
  • PipPipPipPipPip
  • 1,133 posts
  • Name: Tony
  • Year: 1992
Posted 04 September 2013 - 11:19 PM
cant answer that im afraid..diagnostics isnt as black and white when it comes to codes
#13 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,957 posts
  • Name: James
  • Year: 2007
Posted 05 September 2013 - 08:11 AM
Following on from what Tony said:
D147 - Missing / Invalid Vehicle Security Data could be that the PATS system has lost the pairing to the key (probably needs an auto locksmith to repair it with Ford IDS)
I just found this on a Mustang forum:
D900 - Some sort of communication blip has occurred, this doesn't mean that there is a fault necessarily, but it shows that the car has lost communication with itself (when all the lights went out on the dash for example).
E197 and E200 as Tony said, refer to an invalid data for vehicle speed and odometer (this could indicate either a faulty instrument cluster, or could be related to the D900 error you saw above)
A103 is the Antenna Not Connected Error.
These could be indicative of a wiring issue on the car. But as Tony said, you cant diagnose a car solely on the readings of the error codes.
What happens when you turn the key to position II (not started the engine but all electrics are on?)
What do you see or hear? do you see dashboard lights flicker like crazy? hear a clicking in the passenger side? see headlights flicker? I suspect you may do and so would suggest you get the battery looked at.
#14 andysvision
andysvision
  • 144 posts
  • Name: Andi
  • Year: 2006
Posted 05 September 2013 - 09:46 AM
Hmm this is all so confusing,when i turn the key to position II is all normal like before just the lights come on than more of them came off,and than i hear just one click that the start is ready to i think,and when i go to start the engine nothing,,yes yes i see one red light just to the middle od the tempometer and the fuelmetter going on and off crazy,basicly i think i have elctricity but cant start,and the engine system failure shows on the dashboard,, :( desperate
#15 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,957 posts
  • Name: James
  • Year: 2007
Posted 05 September 2013 - 10:59 AM
That is the immobilizer.
The immobilizer is not recognizing the key, and therefore is refusing to start the car. Do you have a spare key? if so try and start the car with the spare key! that should allow you to at least drive the car to a dealer, or a garage with FORD IDS software so that they can re-pair your key and car!
Not what you're looking for?
Also tagged with one or more of these keywords: limp mode
