selloveday
Air Con Not Working At Idle
Hello
I purchased a 2008 Ford Fiesta Zetec S Diesel around five months ago but have noticed a problem with the air con. At first the air con diidn't work at all but we had it regassed and it now does blow cold air.
However the issue is that the air con only seems to blow cold air when I'm accelerating and as soon as I pull up to traffic lights or stop then there is no cold air at all. Then after pulling away the cold air starts blowing again.
Would appreciate any thoughts on what this could be?
Many Thanks
Sarah
very odd! when your sat idling, does the aircon light on the button flash, or turn off, or does it remain on? also, do you have the econetic model?
sounds like its not really getting enough power to run the air con properly.
I would suggest your best bet is get Ford to have a look at it
